starter for the 400m on 77 f250, where to buy cheap/find in junkyard
hi, i had another thread going about starting trouble for this truck, well, turns out, the starter is bad! although i think that might be my fault. trying it too many times for too long probably blew its magnets i think. anyway...
i was wondering, where do you get these the cheapest? my junkyard doesnt have old cars, they like to keep it 90 or newer. do the newer V8 fords use the same starter? or can you get like, rebuild kits? or maybe just the magnets? im so flat broke right now that i dunno what to do. thanks in advance!
While you can get remanufactured starters for $50 and under at the parts stores, they're going to tear up your flywheel in the long run. No offense man, but if you don't have more than $25 in your "in case stuff happens" fund for your truck, a 70's pickup is going to be a handful for you. They're a lot of fun, but the fun doesn't come cheap.
well. new starter is in! had a discouraging first attempted start, barely turned over at all. then i checked my battery and it was at 9 volts, lol. charged it up and it fired right up. now if only i could get my neighbors to move away so i can run it at night to check to see if its still backfiring through the carb. i THINK that problem was from it crossfiring, and ive got new spark plug cables on it and i arranged them to not make magnetic fields, BUT, i suspect i MAY have a bent push rod.
that said, is that easy to repair? i know these old engines have valve covers that pop right off... can you just take the valve parts out easy peasy? pleasy? lol. or at least can i just stick like a screwdriver down there and unbend a rod? i would really hate to have to overhaul this engine. maybe i should make a more appropriately titled thread, after i verify that its not fixed, tomorrow, when its "acceptable" to run my engine. argh.
well, my reckoning is that sometimes my truck backfires through the carb. usually only when revving it. and it immediately bogs down after. i was figuring one of the intake valves isnt closing all the way when the engine is under stress. i believe this to be the case because the guy who sold me the truck had one of the pistons (well, 5 to 6) was crossfiring, and i figure this would put extra stress on the rod. its either the rod or the valve is effed.
well, im pretty sure i fixed the crossfire with a new plug cable that doesnt overlap the others. the timing may be part of it. also the carb may need a rebuild. is there a way to be sure which one is which? like i said, im broke as a dog. still doesnt it make sense that since it was crossfiring some kind of damage may have resulted? buh. anyway. is checking the timing something thats fairly easy? from my understanding you put a test light in one of the spark plug holes (#1 i think?), spin the crankshaft with a torque wrench till it lights up, then put the distributor in a certain way? (maybe just look at it under the cap and see if its lined up with the sparkplug wire for that cylinder?)lol sorry guys im really new at dealing with these older cars. never had a carb or distributor before..
Edit:
PS, the plugs are wired correctly, first thing i checked =P
Edit:
I would suggest you buy a Chiltons repair manual for your truck. I know, your'e broke, but it will answer most of your questions and probably keep you from screwing anything up. It also has a trouble shooting section.
As for the timing.......you'll need to buy or borrow a timing light, then follow the instructions that come with the light or in the Chilton's manual. Very simple. Good luck.
