1966 f100
Old Nov 1, 2009 | 02:52 PM
66-351m's Avatar
66-351m
1966 f100
hello to all the ford truck guys out there, i am a long time ford guy. just recently i purchased my first ford truck. its a 1966 f100, reg cab, reg bed. it came from the factory with a 6cyd 3 on the tree. but i have swapped a 351m/ c6 into it. im having trouble figuring out the factory wiring. so i am unable to get the truck running. any help would be greatly appreciated.
Old Nov 1, 2009 | 05:11 PM
jowilker's Avatar
jowilker
The basic wiring should be the same between the two engines. Did you try upgrading to electronic?
John
Old Nov 1, 2009 | 10:07 PM
66-351m's Avatar
66-351m
the motor has the factory duraspark ignition on it still. but when i got the 66 the 6cyl was out of it already, so i have no idea what wires go where.
Old Nov 1, 2009 | 10:27 PM
jhooch's Avatar
jhooch
Just go on Ebay and get yourself a factory wiring manual. They're on there all the time. It would be a good reference to have. Good luck, sounds like a cool truck.
Old Nov 2, 2009 | 12:26 AM
66-351m's Avatar
66-351m
my plan down the road is to swap an 06 crown vic ifs with air ride, and c notch the back with a triangulated 4 link, shave the rear bumper, other than that it will be the stock color, stock interior with a radio added, and stock wheels. should be a fun toy when its done
Old Nov 2, 2009 | 05:12 AM
jowilker's Avatar
jowilker
66-351m, You are going about this *** backwards. IMHO
You are going to have to pull the engine back out to swap the suspension, most of us here feel the M is a real POS anyways, so..... Why not find a 06 police car with usable front, and swap in the more powerful engine and tranny with OD for a little economy.
You should end up with a nice hotrod with a little sipping grace. just a thought
John
Old Nov 2, 2009 | 05:56 AM
66-351m's Avatar
66-351m
the only reason the 400 is going in the truck is because i got the motor with the truck, and need to use the truck to hull loads with. im not too worried about the fuel economy. i plan on putting a 351w in the truck when i do the suspension swap. and that wont be until next winter at the earliest. thanks for the input tho i do appreciate it.
wolverine2007
New Member Introductions
Feb 4, 2014 12:42 PM
xgkrx
Jul 29, 2012 04:40 AM
rockcandyranch
76
Mar 27, 2012 12:30 PM
snortf100
Oct 21, 2007 10:18 AM
rcb
Sep 15, 2000 08:48 AM
