Connecticut Chapter Join Chapter, Leader:
November B/S thread
Old Nov 30, 2009 | 05:42 PM
  #736
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Jim:
What is the out-out dimension for a masonry fit steel casement for a 36" door?
I want steel so I can grout behind it, and water wicking won't be an issue as the sill is at the driveway with no step.
I need to rip out the existing wood casement for a steel sheathed 36" door that leads into the basement.
The door hangs low at the striker by half a dead throw height.
Since I have to pull the casing to rehang the door, I figured I'd just make it better.
The wall is part cinder block and part framing.
Unless I find some hidden nails, I believe the current casing is secured to the stud via the hinge screws, face - face no wedges, and along the striker edge by what hasn't been carved out of the spray-in polyurethane foam and again no wedges.
The opening has doubled two-by's along each side above the block wall.
The inner two-by's are overhanging the inner face of the block wall, and continue descending down along the face of the block on each side of the opening.
These two-by's have been ripped about in half so that they can make the decend down the sides of the cinderblocks.
I'm thinking of taking out both of the inner two-bys and adding a doubler along side the other face of the original stud, so column strength isn't compromised.
I'm thinking of either a commercial steel door panel or a Therma-Tru door panel.
Old Nov 30, 2009 | 06:00 PM
  #737
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Steel jambs Pg. 11.
http://www.thermatru.com/pdfs/entryDimensionalData.pdf
Old Nov 30, 2009 | 06:04 PM
  #738
tin-man's Avatar
tin-man
Hey Dave and Jim!!
Old Nov 30, 2009 | 06:08 PM
  #739
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Hi David!
How are you this evening?
Old Nov 30, 2009 | 06:26 PM
  #740
Aerocell4x4
Hi Dave
Old Nov 30, 2009 | 06:27 PM
  #741
Aerocell4x4
Thanks Jim and give a pet to Tina too.
Old Nov 30, 2009 | 06:39 PM
  #742
Aerocell4x4
Jim:
Hmmm, split-jamb
I was thinking of the solid casings that one slides in-between the masonry.
As I recall split-jamb wraps around the masonry & or Sheetrock.
I'll have to check the thickness of the block for the split-jamb.
And recheck the opening between the block.
Old Nov 30, 2009 | 06:43 PM
  #743
BIGKEN's Avatar
BIGKEN
Good evening CT...are you ready for some football...Pats/Saints...kickoff in less than an hour!!!
Old Nov 30, 2009 | 06:45 PM
  #744
FORD RANGER's Avatar
FORD RANGER
hey dave,
whats new?
Old Nov 30, 2009 | 06:47 PM
  #745
tin-man's Avatar
tin-man
I be doing fine, 'bout you all!!
Old Nov 30, 2009 | 06:50 PM
  #746
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dave,
That is the only Therma-Tru option.
If you want a mortar-in-place buck I can get you a cut sheet from Canaan Distributors for a UL listed door tomorrow.
Old Nov 30, 2009 | 07:15 PM
  #747
Aerocell4x4
hi there Ken
  #748
Aerocell4x4
Dave: just another night of surfing at work.
Old Nov 30, 2009 | 07:31 PM
  #749
FORD RANGER
daves not here...
Old Nov 30, 2009 | 07:51 PM
  #750
Aerocell4x4
Jim:
Is the buck set up for regular lock-sets versus mortised lock-sets?
Please get me a price for the buck only, and a price for a buck with non-fire rated foam insulated door.
I'd want an in-swing with threshold, hinged on the right when viewed from outside.
As for the door panel, will a Therma-Tru panel mate up with the buck, and would the current steel faced door panel mate up?
My plan of attack is:
I'd pre-stage lumber in the upper section of the buck as I won't be able to get the lumber inside after the buck is slid into place.
I'd mortar it in place at the bottom and finish blocking out the upper half, of course that means counter-sinking the screws in the upper section.
