Sponsored by: Real Truck
Deadly frontend bounce
Old Oct 31, 2009 | 05:35 PM
Powerstrokin_350's Avatar
Powerstrokin_350
I have an 06 F350 5.4, xl, 4x4. If your doing 50-65 mph or so, and hit a pothole or a series of washboards on the gravel roads, the trucks front left wheel will rebound and then continue rebounding. Kind of like once you give the wheel a chance to bounce once, it dribbles itself like a basketball. Almost sends the truck flying into the ditch, or shakes it to a million pieces! Can only stop it by laying on the brakes and slowing the truck down to the point where the wheel is turning so slow it will just balance out. fuel tank in box slides all over, everything in the ashtray is on the floor, cupholders lose their contents. What causes this wheel dribble/bounce effect? It has new shocks, good tires at around 50psi, and 300 gallons of fuel in the slip tank doesnt help either. Its tough to explain but its quite a rush/scary feeling! I would rather have my older model leaf springs back, bad experience with the coil setup! Anyone have any ideas??? Thx
Old Oct 31, 2009 | 06:49 PM
sdetweil's Avatar
sdetweil
shocks, maybe a steering stabilizer/damper
Sam
Old Oct 31, 2009 | 07:01 PM
Powerstrokin_350
Never thought of the steering stabilizer. Ill have to look into a new one maybe
Old Oct 31, 2009 | 08:16 PM
conger's Avatar
conger
When you say new shocks, what is installed. Just because they're new doesn't make them the right one for an SD. Sounds like they aren't providing enough damping action or they may be too stiff and not letting the springs work to allow the tires to follow the surface of the road.
Old Oct 31, 2009 | 08:23 PM
flamebuster's Avatar
flamebuster
might check the ball joints and bushings too..
Old Oct 31, 2009 | 08:51 PM
Powerstrokin_350
I cant remember the name of the shocks but they are supposed to be for my exact sd. I just didnt buy them from ford. Ill check things out tomorrow when I hit my shop
Old Nov 1, 2009 | 01:04 AM
bayou barataria's Avatar
bayou barataria
Do a search for the "death wobble" there are plenty of threads on that subject.
Old Nov 1, 2009 | 01:10 AM
redford's Avatar
redford
FTE Leadership Emeritus
What tire pressure are you running? Ford issued a TSB stating the #1 cause of death wobble (which is what you described) is under inflated tires.
Old Nov 1, 2009 | 01:23 AM
bayou barataria
Glad to see I am not the only one up late.
Old Nov 1, 2009 | 01:50 AM
redford's Avatar
redford
It's not late here. 11:20 AM Sunday in Afghanistan.
Old Nov 1, 2009 | 05:13 AM
sdetweil's Avatar
sdetweil
I missed the one sentence that said he had new shocks and good tires at 50psi.
So, ball joints and stabilizer from the death wobble posts..
Sam
Old Nov 1, 2009 | 06:06 AM
redford's Avatar
redford
Sam
I missed it also.
If I lower my tires to 50 PSI my truck would wobble all over the place.
Old Nov 1, 2009 | 07:41 AM
senix's Avatar
senix
I would be doing what others are saying too. check those tires and shocks,ball joints first. TP Pressure.
Then you might look at your steering stabilizer as a possible remedy to the wobble, but I would be checking other items first.
Old Nov 1, 2009 | 11:05 AM
Powerstrokin_350
will do, thx!
Old Nov 1, 2009 | 11:21 AM
johnnysF350's Avatar
johnnysF350
Air those tires up 50 is to low up front, especially on a diesel. I believe 65 is recommended. I know when my tires start getting low I see the wobble. Airing up seems to cure it.
