*Engine swap* few questions
Old Nov 8, 2009 | 10:14 PM
JFlom77's Avatar
JFlom77
update...
got the motor out, went pretty smooth, i left the T/C on the tranny.
waiting on a few parts in the mail.
went with the comp cam extreme energy 262in 270exh 4x4 cam and lifters.
tore apart the old engine. found a bad lifter, the bottom of it was mashed up and the cam lobe went flat, only on one lifter, any idea what would cause this???? i replaced the lifters recently, did everything by the book and one failed, could it be a faulty lifter?
here are some pics
best i could get of the lifter compared to another.
Old Nov 9, 2009 | 08:49 AM
Conanski's Avatar
Conanski
That cam you picked is not EFI compatable, you need one with 114LSA or greater and less than 215deg intake duration.. preferably quite a bit less to produce a steady vacuum signal. Your choices aren't great since Crane went under but the Comp cams 35-255-5 fits the bill.
Old Feb 22, 2010 | 05:20 PM
JFlom77's Avatar
JFlom77
Finished the swap awhile ago, forgot to post.
went with the comp cam 35-255-5
Motor is awsome, lots of go.
Big_Rob
S. California Chapter
May 31, 2013 12:34 PM
jfritts
1978 - 1996 Big Bronco
66
Feb 4, 2013 10:16 PM
hav24wheel
47
Nov 7, 2012 08:56 PM
AbandonedBronco
Nov 14, 2011 08:49 AM
msuforeman
2009 - 2014 F150
May 23, 2011 04:37 PM
