Tire ?: Toyo MT 285/75r17 (~34s) on 17x8s
I have a 2002 7.3L 4x4 Ex. Last weekend I replaced the stock front springs with some "X" springs and swapped the rear block for the taller F350 block.
I see lots of posts about fitting 285/75r16s (~33s) on stock springs.
I am hoping to fit 285/75r17 (~34s) now that my Ex sits a little taller.
For the tires I am looking at the Toyo MT LT285/75R17, Load Rang E/10 ply, Max load 3195 lbs, Max pressure 80 psi.
For the wheels I am looking at the American Racing Teflon Mojave 17x8 with 4.5 BS.
Do you guys think this set up will work with my "X" spring lift (+2.5")? I don't mind trimming the valance or massaging/trimming the plastic fender liner. Is the max load range of 3195 lbs enough for the Ex?
Main purpose for this vehicle is towing my jeep on a 16 foot car hauler.
I appreciate any advice before I spend the cash.
Before Stock Springs/Blocks
After "X" springs and F350 blocks
X-springs are replacement front leave springs from an F350 with snow plow package. They give you ~2.5 inch lift up front.
X-Springs ... part number 2C3Z*5310*AF
Clearance to bump stop before
Clearance to bump stop after
X-spring next to stock Excursion spring
Not sure if I have before measurements maybe on a scrap of paper somewhere in the garage . After measurements were 39.50" Front and 40.50" Rear with 265/75r16s. I'll get new measurements tonight with the new wheels/tires.
Thanks. Noise is minimal. You will not have to crank up the kids dvds.
