Valve cover
Valve cover
I am working to clean up the engine bay of a 1986 4.9L for appearance sake. The original valve cover has the two posts near the fire wall which were used for holding the emission components which are no longer being used.
What is a good year of engine to be used as a donor for a replacement valve cover without these posts?
Thanks!
Thanks!
Hi i just bought a chrome valve cover off ebay. For 15 and 12 shipping. Ill let yall know how it goes.
Chrome steel Ford 6 Cylinder Valve Cover. Fits 1965-1987 Ford 250 and 300 straight 6s. 3 1/4" tall with baffled breather holes.
Heres a link of the same one i bought.
Ford Chrome 6 Cylinder Valve Cover 250 300 1965-87:eBay Motors (item 220500640155 end time Nov-01-09 20:31:30 PST)
Hope that helps some yall have a good day.
I'm sorry, I'm just a little technologically retarded, and the few pictures I do have of my truck don't seem to want to upload. But as for telling you about it, it's big, old, slow, and has rust holes in the rear wheel wells. But seriously, what do you want to know about mah truck?
Geeze, interrogation, huh? just joking. I got it because it was an 80-86 body style ford pickup, it was a 3/4 ton, good for heavy hauling, it had a 4 speed w/ granny low (I don't like slushboxes-I mean automatics...), it was a 4x4 (gotta have that up here for snow and going wheeling) And most important of all, it had a FORD 300 CI inline six. And it was only 400 bucks (knock in the engine, yes I know wtf you never find a ford 300 inline with a knock in it, turned out to be a timing gear missing teeth)
I plan on getting rid of that crappy Carter 1 bbl carb soon and replacing it with a 4 bbl, offy manifold, EFI exhaust manifolds. I have also been toying with the idea of an sas (solid axle swap for you non 4 byers) dana 60 front that is, and getting rid of the semi floating 10.25 and trading it for a full floater, and some detroit lockers eventually. So basically giving it the title of "locked one tons" And probably a couple inches of lift.
