did the Tstat in my 302 now all of a sudden it idles like ****....at idle in park it sounds like it is choking out and drops over 200 rpm and sometimes dies out, put it in reverse it dies unless you hit the skinny pedal...but it takes a couple mins to start this after firing it up
i was thinking IAC valve...replaced that and still does it at idle in park but i did not notice it in reverse as bad any way...
could this be a timing issue? when i did the T stat i had to loosen and rotate the whole distributor to get at the bolt in the t stat housing do you think rotating the dist. could knock the timing out of wack?, i tightened it back down and tried to get it close to where it was before
fuel pump sounds strong when i turn the key on
pulled the codes and got
1) 179- right side rich @ part throttle (another reason i was thinkin IAC, not getting enough air)
2) 327- DPFE circuit below min. 0.2 volt...any knowledge here i have no clue what this one is
3) 328- EVP circuit below min. 0.2 volt...think that could be the cause?
just tryin to gather some ideas here...lemme know if im on the right track
well the plug for the wiring harness was in the way of the wrench and i could not get on that pesky lower bolt any other way... all i did was loosen it and rotate it then put it back where it was and tightened it back down, i didnt think that would change the timing any?
im gonna check into the EVP and fix that up, im thinking that might be a cause for it also
wheres the TPS located again? near the pedal? i thought the TPS would throw codes if it was malfunctioning
and im thinking the EVP code and the running rich code are related and they both might be related to the idle problem i am having, because it feels like it it choking out which i would think to be air intake, and if it is that bad it might also be bad enough to cause the engine to run rich @ part throttle because it is not getting enough air
the other code for the DPFE circuit, i dont know what the DPFE circuit is so i cant even begin to fix it hahah
yeah the DPFE and the EVP do the same thing from what it looks like, so the EVP is bitched so the computer throws codes for it and/or the DPFE
no clue whats telling it the right side is rich but thats what it tells me
since i changed the IAC the CEL has not been appearing nearly as often, i rarely see it now as opposed to every 10 mins at least... and it seems to go away faster, so i have to check the codes again and see cause something must have disappeared
depending on what happens tomorrow i might be parking the truck for half year at least so its not a huge deal
winter coming soon...it got sketchy with the 4x4 last year and this year is supposed to be worse, plus with school right now i cant afford to insure both of them
sure does, but i wanna figure this out in case i try to sell the bitch lol...i have a good list of stuff to check out so once the 4x4 is on the road and im done spending money on it for a while i will fix up the ole 91 and sell it
