Help with self-test codes
Old Oct 1, 2009 | 05:30 PM
IMRAY69's Avatar
IMRAY69
Question Help with self-test codes
Need some help here. Just read the codes on my 92 f150, 5.8L and i'm kinda confused. The first blinks were 1 -1/2sec pause- 1 -1/2sec pause- 1 -4sec pause- then repeats one time. After that I get 1-3-2-7-3-2-8-5-4-2-3-2-7-3-2-8-5-4-2. That is the end. No more codes after that. Waited for approx. 30 sec with no other blinks.
Please give me your best bet.
My guess is codes 32,73,28,54,2(last flash)
In order: EVP circuit below min. voltage of 0.24 volts, No KOEO for 73, VAT sensor out of test range, ACT sensor signal is greater than the self test max of 4.6 volts, and no code meaning for 2.
I have recently changed the plugs(less than 5,000 miles ago, cap, rotor, oil change, Drivers side valve cover gasket, will do the passenger side this weekend along with the egr valve gasket and the upper intake plenum gasket. O2 sensor done at same time as plugs. I have two new fuel tanks replaced approx. same time as plugs.
Reason for all the testing is that it idles rough at stops when warm and stutters and bucks (like it's missing) when I am in OD above 40 mph and trying to accelerate. Runs ok when under slight pedal pressure.
Old Oct 1, 2009 | 05:42 PM
skaterbro's Avatar
skaterbro
I might be wrong but i think you're 3 digit code. If it is it'd be 327, 328 and 542. You said KOEO.
Old Oct 1, 2009 | 05:59 PM
IMRAY69's Avatar
IMRAY69
Correct. Key on engine off. When I looked at the ffi site at thier 3-digit codes, there were none listed. Did I miss them?
Old Oct 1, 2009 | 07:41 PM
IMRAY69's Avatar
IMRAY69
OK, codes:
327- DPFE or EVP circuit below min. voltage of 0.2 volts
328- evp circuit below min. voltage of 0.24 volts
542- fuel pump circuit failure
Forgot to mention I was replacing a fuel return line last night and relieved the fuel pressure with the inertia switch. I hope that is why the fuel pump circuit failure came on.
Now, since I do not have a catilytic convertor on the truck, would I still need to worry about the egr valve position sensor? Probably as long as the egr valve is still on the truck and not blocked off, huh?
Thanks for the help.
Old Oct 1, 2009 | 08:28 PM
EPNCSU2006's Avatar
EPNCSU2006
I believe so. It will also trigger this code if you switch between tanks with the engine running, although it really won't hurt anything.
Old Oct 2, 2009 | 07:50 AM
IMRAY69's Avatar
IMRAY69
Bump this up to the top.
Old Oct 2, 2009 | 09:18 AM
Conanski's Avatar
Conanski
You have a bad EVP sensor it will likely need to be changed. Your truck is a '92 so it shouldn't have a DPFE sensor. EVP stands for EGR Valve Position sensor, it is on top of the EGR valve.
Old Oct 2, 2009 | 10:16 AM
IMRAY69's Avatar
IMRAY69
That's what I was thinking also. I'll change that and let you know the outcome. Thanks for all the help.
Old Oct 27, 2009 | 04:19 PM
IMRAY69's Avatar
IMRAY69
Little answer to my prayers
Thought I would update the thread by letting you know that the problems with the truck seem to have been the plug wires. I have now put my third set on the truck and hopefully this works for a while longer than the last. I will also be in the market for plug wire sleeves. The asbestos type. Anybody know where I can get some for a decent price?
Trucked
1997 - 2003 F150
Sep 22, 2011 08:04 PM
Django92
Jan 19, 2011 05:52 PM
geodiggr
17
Aug 24, 2009 09:24 PM
Fordenthusiasts
Aug 27, 2008 09:30 PM
steve83
Computer Chips & Tuners
May 19, 2003 05:50 PM
