can't figure it out, HELP!
Old Oct 29, 2009 | 01:50 AM
IsoGrifo's Avatar
IsoGrifo
My brother bought a 75 f-150 with a 390 and a c-6 tranny. when he got it it had been sitting for a couple years, and the oil looked horrible, so he changed the oil, did a coolant flush, changed the fuel lines and pump, put a new carb on (or rather an old one we had laying around) drove fine for a day, now it idles fine, but when you put it in drive, it kills unless you are flooring it, and when flooring it in drive the fastest it will go is about 15-20 mph. tried adjusting the carb, no luck, tried three other carbs, no luck. the manifold had a hole that was suspected to be causing vacuum leak, plugged it, no luck. searched all over for vacuum leaks, couldn't find any, now we're lost. any help would be greatly appreciated.
also posted on the FE Forum
Old Oct 29, 2009 | 07:14 AM
pidaster's Avatar
pidaster
Possible transmission problem?
Old Oct 29, 2009 | 07:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TYPICAL Auto-Lite/Motorcraft 2V carb problem. Affects the following carbs: Barely used, somewhat used, some badly in need of help!
Bogging down, hesitating, stumbling from a dead stop or accelerating at speed: Time for a new Accelerator Pump and Check Valve.
The check valve is the same 1962/79: C4AZ9576A (Motorcraft CM825).
There are two different acc. pumps: 1962/74 is the same (C4AZ9B559A-Motorcraft CM463). 1975/79 is different: D5AZ9B559A (Motorcraft CM2092).
Hole in the intake manifold: This is where the choke's pre-heat tube connects.
T'other end connects to a fitting on the choke body. Most autoparts stores carry a 'universal' pre-heat tube kit....
Consists of copper tubing, nylon "blanket" for the tube, nuts and ferrules.
Coneynew
19
Jul 31, 2012 01:29 PM
Condor945
43
Mar 8, 2012 06:32 PM
lifted77f250
Nov 4, 2011 11:59 AM
hismuddpuppy
1978 - 1996 Big Bronco
Jun 7, 2009 12:04 PM
Hellbore
May 23, 2006 05:22 PM
