Tech link Help needed
Old Oct 28, 2009 | 04:46 PM
monsterbaby's Avatar
monsterbaby
As was noted in another thread some of the tech links are not working. Seems the site that was hosting them has been shut down.
So I am trying to go through and find which ones don't work and see if I can locate the info somewhere else.
This is where I need your guys help if you can and have the time (my time is limited too). If you know where to find some of that info then PM me a link to look at with the title of the current link so I know which one it replaces and I will try and get this all updated if possible. Whatever ones I am unable to find I will end up removing (although may put them into a seperate post so someone will know which ones need replaced)
Thanks for your help guys
Rob
Old Oct 31, 2009 | 04:38 AM
tomw's Avatar
tomw
I don't know how to PM, even after being here for years. I grabbed a Word .doc for the 2.3 timing belt and can send it if you want.
tom
You can delete this as you see fit...
Old Oct 31, 2009 | 12:22 PM
monsterbaby
Tom if you can just start a thread and post that. then I can change the link to go to that thread.
And posting in here works too, helps keep this to the top.
But to PM, click on the users name and a drop down box will appear, go down to "send private message" clck on that and a message box appears and you can then send your PM.
Old Oct 31, 2009 | 01:20 PM
tomw's Avatar
tomw
Ummmh, I can't post attachments per the little box on the lower left labeled "Posting Rules". Tried a 'new thread' and then looked to see where to hook up the file to upload it and crunch, ran into the guardrails.
Want me to send it attached to an email?
tom
