Sponsored by: Real Truck
Fuse Question... Help ASAP
Old Oct 28, 2009 | 04:48 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty
my Bully Dog Triple Dog GT Tuner should be arriving today for my 06, so im reading up on the installation instructions on Bully Dogs site before it gets here... it says to run the power lead to a fuse that has "key on power", I looked through my owners manual and found 2 possible solutions... Fuse #27 which is Ignition Switch RUN Feed OR Fuse #45 which is Ignition Switch RUN/START Feed... or could I use Fuse #29 which is Customer Access? what is that?
Im thinking it would hook into Fuse 45... but anybody is welcome to chime in and prove me wrong... I emailed Bully Dog about it but lord knows when there gonna email me back. Any help is greatly appreciated! Thanks in Advance.
here a pic of the GT, Ill post install pics later.
Old Oct 28, 2009 | 05:39 AM
Robs06SuperDuty
welll ive been searching for a bit and I think im going to hook it to the Customer Access Fuse. But I'd still like to hear others opinions...
Old Oct 28, 2009 | 06:12 AM
junque2k2's Avatar
junque2k2
When I added a CRL power rear slider to my 03 F250 I used a Littlefuse Add a tap adapter so I didn't have to cut any wires or jerry rig the fuse box. I found several unused fuse sockets that were hot. For a hot in run wire the CRL tech advised splicing into the black wire running up the steering wheel column.
I think the Customer Access fuse is for a console cig lighter.
Old Oct 28, 2009 | 12:35 PM
Robs06SuperDuty
i think the kit comes with one of those fuse taps so theres no cutting anything. from what I read and understand the Customer Access it only has power to it when the key is ON and doesnt have power when the truck is off or in ACC mode. which is exactly what I need. im still waiting on the UPS man...
Old Oct 28, 2009 | 12:45 PM
senix's Avatar
senix
i would put it in the customer access one if there is currently some power to it. This would ensure you don't overload the others and prevent the truck from running. I don't that would happen but stranger things have before.
Do you have a tester so that you can check for power? What you don't want is power at that location with the key out.
Don't want to run the risk of a dead battery
Old Oct 28, 2009 | 04:37 PM
Robs06SuperDuty
yeah I have a multi Circuit tester... dad might have another type of tester... stupid question but i can use my multi circuit to test voltage by pullling the fuse and probing eaching side of the fuse clips and having someone turn the key ON and OFF etc right...? I dont use it enough to be familiar with how to check things.
Old Oct 28, 2009 | 04:38 PM
senix's Avatar
senix
that is how to do it. check for power with key off and then with key on.
Old Oct 28, 2009 | 04:40 PM
Robs06SuperDuty
alright just making sure... thanks Senix. Ill do that after work.
greenacres36
Computer Chips & Tuners
Jan 21, 2016 06:29 AM
Maiger
Dec 29, 2014 07:59 AM
Lee44054
Apr 27, 2014 11:05 AM
UncleShank
Apr 25, 2011 11:48 AM
Robs06SuperDuty
May 24, 2010 11:17 AM
