IWE Vacuum lines
Old Oct 27, 2009 | 07:30 PM
jwillyf150's Avatar
jwillyf150
IWE Vacuum lines
Hey all, haven't posted on here in a while, but still check in from time to time. Well here lately I've been hearing a faint rattle coming from driver side front only when I accelerate heavy and going up hill underload and I know it's not hub or actuator going out since I changed both sides last winter, so I got to looking and luckily found a pin hole in vacuum line going into actuator on driver side. I guess losing that vacuum while accelerating my actuator didn't know whether to engage 4X4 or not hence the noise. Got some duck tape and wrapped tightly around line to cover hole and waa laa noise is GONE!!!! Just wondering if any of you experienced anything like this and just wonder how long my fix everything duck tape will last until I have to move to my next solution gorilla glue.
Old Oct 27, 2009 | 09:46 PM
stronger's Avatar
stronger
I patched a hole in mine with some rather stiff, cheap, clear tube that I located at Lowe's for about 30 cents. I cut the line at the leak, put a small dab of rtv on the ford lines and slipped them into the clear tube. it was a near perfect (tight) fit. I could see that the rtv was not plugging anything. a week later I found a collection of small vinyl or plastic vac nipples and T's at Autozone so I cut my 30 cent fix back out and replaced it with a $2 nipple.
Old Oct 27, 2009 | 09:59 PM
Roller150's Avatar
Roller150
Duct tape should hold a long time on that.
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
boxcarwilly
Jul 24, 2018 05:01 PM
Hunter_97
2004 - 2008 F150
Jan 26, 2017 05:51 PM
Capt No Slack
2004 - 2008 F150
Jan 6, 2017 07:58 PM
Torky2
1978 - 1996 Big Bronco
Nov 16, 2016 11:21 PM
