2004 Exped Puddle Lamp
Old Oct 27, 2009 | 07:08 PM
trey99's Avatar
trey99
anyone have any clue on how to change the bulb on these lamps. i dont want to rip the cover off and then have to buy a mirror. 2004 Exped Eddie with puddle lamps and turn sigs.
thanks in advance
trey
Old Oct 27, 2009 | 07:40 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
thanks in advance
trey
It's outlined in the owners manual. Sorry, I don't know off hand.
Tim
Old Oct 28, 2009 | 06:54 AM
apgarassoc's Avatar
apgarassoc
Replace Turn Signal and Puddle Lamp in Mirror
You need to pop out the mirror by squezzing your fingers in around the rim of the glass and pulling toward you. Once it is out, remove the electrical connector from the back of the glass (supplying power to the defrost heater) and set the glass aside. You will then see tabs that are holding the lamp assemply against the bottom frame of the mirror assembly. Squeeze the tabs to release the lamp assembly. You can then remove the bulbs for replacement.
If you want to replace the front cover of the mirror assembly, this is the time - you will see the tabs holding the cover against the mirror frame once you remove the glass.
Old Oct 28, 2009 | 09:13 PM
trey99's Avatar
trey99
thanks peeps, i would have never thought they put that in the owners manual. i got it out and read it from cover to cover, learned a few things, but knew the majority.
thanks again
trey
Old Oct 29, 2009 | 05:20 AM
tseekins's Avatar
tseekins
thanks again
trey
Welcome to FTE! The owners manual is a great resource. Most people that I know wouldn't dream of reading it, but I always read it from cover to cover.
Since I have so few proplem with my Fords, I normally forget most of it.
Tim
Old Oct 29, 2009 | 08:49 PM
trey99's Avatar
trey99
well now im looking for a lens for my mirror. the manual is not the right directions, it says remove screws, there are no screws. tried the other above mentioned method, could get to the tabs without removing glass, got one loose and pulled the lens from its base. oh well.
thanks anyways and if you know where i can buy just the lens let me know. havent chcecked with the dealer yet to see if lens is sold sep.
trey
Old Nov 10, 2009 | 08:48 PM
BASE864's Avatar
BASE864
Look for the screw
There is a torx screw on the inboard front side of the lens pod. You have to fold the mirror forward just a little bit to get to it. Once you remove the screw, the lens pod will pop out (down). The two tabs mentioned are on the outboard side of the pod.
There's also a metal clip that holds the outboard side of the len to the mirror. It's helpful to use a straight screwdiver to work the clip out. Shine a flashlight between the bottom of the mirror glass and the mirror housing and you should see the clip.
You can buy the lens separately. It you want to go clear (smoke like the 2005 & up Limited's) get the smoke or get the standard amber. Cost was around $35 or so.
Bugzilla46310
Feb 3, 2020 04:32 PM
A/Ox4
2009 - 2014 F150
Dec 27, 2016 08:53 PM
dougasy
2009 - 2014 F150
Nov 29, 2016 07:42 PM
BigBlue92
2009 - 2014 F150
Mar 26, 2016 04:28 PM
burre
Nov 29, 2003 05:11 PM
