Help Needed please
Old Oct 27, 2009 | 02:08 PM
johnkirk's Avatar
johnkirk
Help Needed please
Hey fellas,
I have a 1999 Ford Expedition with a 5,4 triton V-8. I lost all of the coolant out of the right rear of the engine the other day. Wwhen I re-fill the radiator the fluid runs right out the rear right of the engine. The oil level is ok which is good. We are going to remove the lower intake manifold to see whats up. I was checking online to see what a lower intake manifold costs, & I cant find one. I find other years but not 1999. Is there something soecial about this part? Any help as far as where I can maybe find this part is greatly appreciated.
Thanks!
John
Old Oct 27, 2009 | 04:05 PM
alloro's Avatar
alloro
Do you know for sure you need a new intake?
Could it be a freeze plug or just the intake gasket?
Could it be the heater hose fitting over there?
Here's an intake for a 99.
1999 FORD EXPEDITION Intake Manifold
Old Oct 27, 2009 | 04:11 PM
johnkirk's Avatar
johnkirk
The freeze plug and hose fitting are fine. Not sure about the gasket.
Old Oct 27, 2009 | 04:14 PM
johnkirk's Avatar
johnkirk
Is this the lower intake manifold?
Old Oct 27, 2009 | 04:20 PM
alloro's Avatar
alloro
The description reads:
DORMAN Part # 615285 {OE Solutions}
Includes All Gaskets and Seals as Required; Lower
Click the "More Info" link on the right to see a picture of it.
Old Oct 28, 2009 | 12:20 PM
benningstspeed1.0's Avatar
benningstspeed1.0
there are two collant hoses that attatch back there. i have seen both of the steel tubes rust out before.
Old Oct 28, 2009 | 12:56 PM
alloro's Avatar
alloro
Originally Posted by benningstspeed1.0
there are two coolant hoses that attach back there. i have seen both of the steel tubes rust out before.
Ford OEM parts? Go figure!
Old Oct 28, 2009 | 01:53 PM
benningstspeed1.0
ford oem parts? Go figure!
they lasted 11 years, must have been
Old Oct 28, 2009 | 04:30 PM
alloro's Avatar
alloro
That's true since aftermarket tubes would've lasted 25 years.
Old Oct 28, 2009 | 08:54 PM
benningstspeed1.0
got me there. i am going to sell my navi and see if i can buy a better one at autozone.
oh, what do i mean see if i can. thats a no brainer all aftermarket is better and cheaper.
Old Oct 29, 2009 | 12:14 AM
alloro's Avatar
alloro
Now that you've attained step one, you'll need to start working on step two. Step two is to quit your job at the Ford dealer and go work at Autozone. You'll be a much happier person for doing this.
