1988 4.9 Knock Sensor
Old Sep 20, 2020 | 12:24 PM
BBQSue's Avatar
BBQSue
Same
Originally Posted by Austin Yates
I am also having erratic timing issues. Unplugging the sensor that most have been referring to as the knock sensor clears it up to where the miss is almost non-existent. All the parts listed in previous post are what I've replaced. With sensor plugged in. When i first start the truck it idles high as most do from initial start up. Runs smooth. Drops rpm to its normal operating idle. At this point sometimes itll idle for a bit sometimes it will immediately start to choke. The length of time is never the same. Then like i said it chokes like u pulled a main vacuum line. Idles down rough like it wants to die. Im assuming at this point the sensor is adjusting timing and it idles up fairly high stays there for a moment and slowly drops back down to regular idle. Theres a intermittent "puh" sound. Like when enunciating the letter P. Then it repeats the process all over again. Almost dying then smoothing out almost dying smoothing out on and on no matter the temperature. Its not a until it warms up thing its not a once its warmed up thing. The amount of time it idles good after initial start is never the same and the amount of time it struggles to idle correctly is sometimes short and sometimes it takes it a minute. The time it runs smooth after its little fit is almost always different also. Im perplexed to say the least and about ready to be done with it all together.
Man I've had the same experience with my 95. I'm working up the courage to take a look at the rear fuel pump/filter next.
Old Jun 12, 2023 | 12:04 PM
FordTruck1991's Avatar
FordTruck1991
3rd Gear
My 1991 has a knock sensor on the driver side front just under the ignition coil. I unplugged it and found it stopped the stumbling and studdering on startup. Seems to run a LOT smoother without it. The engine is not pinging or knocking and has been running fine.
Another thing I did that made things better overall was to replace the fan clutch. I did not realize how heat could make sensors not function properly. It was a hard but welcomed (somewhat humbling) event. The truck starts and runs easier, doesn't get hot, air conditioner is colder, and idles smooth.
1918ALF
Feb 22, 2017 06:14 AM
jb50F1
Nov 12, 2016 03:34 AM
CraniX
15
Feb 20, 2012 12:10 AM
jhicks32
Feb 10, 2009 03:39 AM
frank1
Aug 31, 2005 06:04 AM
