vinyl vacum lines
Old Oct 26, 2009 | 09:10 PM
vancouver island's Avatar
vancouver island
vinyl vacum lines
Does anyone have any ideas my ford 89 has those stock vacume lines and I went to napa to replace them I think I can hear a leak wright were they join the rubber fittings. I was told they almost never go bad and just to use seal all around the part that joins to the rubber (stock lines)
Old Oct 26, 2009 | 09:45 PM
Elderstarr's Avatar
Elderstarr
LOL! "Never go bad". After years of heat cycling and the all the salt you have on Vancouver Island, that plastic has to give sometime. I have had the same experience down in the Okanagan. If possible, just replace all the vinyl with rubber and never worry about it again. The worst lines you have to watch out for are the a/c control lines to the fresh air door. They are the main culprets of a vacuum leak.
You could just seal up the leaks, but it's delaying the inevitable.
Old Oct 26, 2009 | 09:48 PM
vancouver island
Yeah that is what I thought. Don't have air conditioning if that is what you meant so no worrys their. Do you have to use the exact size diameter or can it be a bit bigger. just want it to idle like new.
Old Oct 26, 2009 | 10:05 PM
Elderstarr's Avatar
Elderstarr
Tighter fit, the better. If your repairing a damaged section of vinyl lines, I will usually cut a rubber line that fits nicely over the vinyl line, then apply some rtv on the outside of the vinyl line before slipping the rubber line over it, just as insurance it will not leak.
Old Oct 26, 2009 | 10:11 PM
vancouver island
Yeah I would but my vinyl have those rubber fittings that they are attached to. so I cant fit the rubber over. what about just replacing completly with rubber
gbrewer
Nov 4, 2010 11:48 PM
vancouver island
13
Nov 10, 2009 05:45 PM
ElwoodMurphy
Nebraska Chapter
Sep 18, 2008 02:06 PM
bama_bo
Nov 26, 2003 08:06 PM
