79 transfer case bearing?
Old Oct 26, 2009 | 05:20 PM
ford42's Avatar
ford42
i have 79 ford 150 and i have play in the front shaft of transfer case. it makes a grinding noise when in 4wheel.is there a bearing there and what i can do 2 fix it?
Old Oct 26, 2009 | 05:49 PM
75F350's Avatar
75F350
Yes there is a bearing there. You must remove the driveshaft, then the yoke, and then remove the 4 bolts on the aluminum seal retainer. You will expose the bearing and then determine whether or not it has to be replaced.
Be very careful to acknowledge which way the seal retainer is installed. It can fit several different ways, but because of the oiling hole, it should only fit one way. If you rotate it in any way, it will not oil the bearing and the bearing will destroy itself.
This is true for Np 203's as well as 205's.
Old Oct 26, 2009 | 05:57 PM
i-w's Avatar
i-w
Here is a great link to a rebuild of the np205 with a ton of pictures.
Project Code Name "Double Agent"
Pics and how to.
NP205 Rebuild with pics
Old Oct 26, 2009 | 06:46 PM
ford42's Avatar
ford42
thx
thx was wondering if it was somthing i could tackle myself.
Old Oct 26, 2009 | 06:49 PM
ford42's Avatar
ford42
thx
Pics and how to.
the pics helped. thats what i was wondering if the bearing was pressed in. the pic shows a snap ring. so i can tackle this myself!
Old Oct 26, 2009 | 07:28 PM
i-w's Avatar
i-w
Glad i could help! well Glad i could point you in the proper direction.
fiel196
Oct 24, 2015 11:10 PM
dougegoble
Mar 24, 2015 03:15 PM
papecat
WTB - Parts & other
Jan 25, 2015 10:01 PM
tjg79
Ford Truck Parts for Sale
Mar 26, 2014 09:59 AM
RobFox
Mar 9, 2014 08:35 AM
