1970 F100: Which engine/trans combo?
My 70 is missing its driveshaft too and I can't locate a used one anywhere nearby. I'd like to just take everything from the engine to the driveshaft from the 82 and drop it into the 70. I'm wondering how straightforward that would be. I've got an old Chilton's manual, which is helpful, but doesn't tell me everything and I just can't find any reliable source of information on the internet. I've got a column shift lever for a 3-speed C4 in the 70. It doesn't look like replacing the steering column is too bad, so I'd switch that too,if I need to. I've got more time than money right now, so I'd like to make this work even if it means spending a bit of extra time on the job.
I'm sure I can figure it out by myself eventually, but some experienced advice would be very handy before I get too far into a bad idea. Tomorrow is likely the day I decide to buy the 82 or not.
Anyone know if this idea works? I really don't have anyone else to ask, so please don't hold back if you know more that me, which is just about all of you.
I am thankful that I rebuilt both my engine and tranny before installing, so I know that I have 36,000 moles on the rebuild. Bossman has to go when I'm ready of he can get a .45 slug through the grill.
Gas prices are going up again, the 302 would be a reasonable choice. It would have to have a OD behind it to go in my truck. I think EFI would make a good choice if you have the time to plan it out.
guluk
John
I still haven seen my potential donor truck, but I'm going this afternoon if we can coordinate schedules. I've come up against a bit of a problem though. I found the "82 F150 through someone else. I've now had a chance to speak to its owner and he tells me its got a speed floor shift. I'd love to use that, but that adds the problem of adding a clutch pedal.
I tried searching car-part.com to see if I could find a donor clutch for my year truck, but it isn't even listed as an item from what I can tell. I it is, I don't know what to call it. I tried everything I could think of. Would one just bolt on and then be reasonably easy to adapt if I do find a clutch pedal. I'd obviously need to cut a hole for the shifter, but that doesn't seem like a big deal.
If I can look at the 82 this afternoon, I'll try to identify the transmission. Anything I should look for while I'm under it that might help figure out how to make it fit? Also, would I be better off trying to use the driveshaft from the 82 or find something else if I did put that 4-speed in? The rear of the 70 truck looks to be stock, but I haven't looked real close yet.
One last question. The 70 doesn't have any engine supports. I'm still looking for a useful diagram, but from what I understand, there should be risers that the actual motor mounts bolt to. I don't have them. Am I correct? What should I put in to make the 302 fit?
Thanks again!!
Not bad at all! What does it get unloaded running 60-70mph?
It runs and sounds great and it's got a driveshaft and transmission, not to mention all the other stuff like alternator etc. I'm much happier with that than a junkyard engine I can't hear run first.
I'm going to try and put the 4 speed in too. Putting a hole in the floor can't be too hard. I've put holes through cars before, can't be too much harder to do it on purpose. I've got a place I can go search through several old trucks and can probably find a clutch pedal.
What I'm wondering now is how to connect the hydraulic clutch on the 4speed to the non-hydraulic clutch pedal on the 70 once I put it in. Is there an easy part swap to make the hydraulic clutch manual, or would it be better to try to fit a master cylinder to the clutch pedal somehow?
My 76 F100 originally didn't have a panel in the floor as it was a column shift 3sp. I also had a 69 F100. It was the truck I got my T18 4sp from that made it into my 76. The removable transmission floor panel in the 69 matched an embossed pattern in the floorboard in my 76 exactly. I only had to cut just inside the embossed pattern to use the 69 panel in my 76. I've seen some of these trucks with a removable panel with no shifter hole in them.
Regarding engine stands:
302's share an engine perch with 351M/400 in 73-79. I believe that cab forward, the frame of a 67-72 is the same as 73-79. When I swapped out my 300 I6, I had to acquire the 302 perches (which i still have and am not using). I believe that 300 shared a perch with 352/360/390. There were holes in the frame and crossmember for either. It was only a matter of knowing which I had and bolting them in. The 302 perches have mounting holes a couple of inches closer to the firewall than the other perches.
Regarding clutch pedal:
In my 76 it was easy. I had the original clutch pedal as it originally a manual. When I removed the pedal and wanted an automatic setup, I discovered that the automatics I looked at used the same brake pedal. I just needed a bolt that replaced the stud welded to the side of the clutch pedal. I never looked at my 69 (I no longer have it) closely to see if it was the same, but I've discovered my 79 is significantly different in design. If your 70 is the same as my 76, then you just need the clutch pedal itself. Just pull the bolt out that the brake pedal pivots over and replace it with the clutch pedal. If you end up going with the kind of mechanical clutch linkage used in the 60-70s trucks, get the little cast piece that bolts to the bellhousing that has a bushing for the inside of the Zbar on it. There would also be a frame side piece with the bushing for the other side of the Zbar. Your floorboard should have the hole for the clutch rod in it, probably covered with a rubber plug. If you figure out how to adapt a hydraulic system, I'd like to know how it goes together. I believe there is room on the firewall to mount a hydraulic cylinder. Just don't know how the rod geometry would work connecting to a pedal.
Adding the clutch assembly would be above my pay grade, and not necessary IMHO with all the good automatics available. Shifting gears is a job that I don't NEED to do.
John
