Truck issues
Old Oct 26, 2009 | 09:50 AM
deereman4020's Avatar
deereman4020
Truck issues
Hey y'all, Im having some issuses with my truck. First off does anyone know where the inertia switch is located and do you have a pictures of it in its location. Second me and my dad were trying to get my truck to run it turns over and fires when wd40 is sprayed in to the intake, the pumps are good we testd them with jumper wires from a battery, we have the problem narrowed down to the wiring we think the problem is the inertia switch, so in attempt to fix the problem but with out resetting the inertia switch we ran wires to both of the pumps and to a fuse in the fuse box, we had the truck running but she died and now we have no power to any thing. Do you think we fried the PCM with our re-wireing attempt?
Old Oct 26, 2009 | 10:48 AM
subford's Avatar
subford
Rewiring the fuel pumps should not hurt the PCM.
Old Oct 26, 2009 | 01:00 PM
deereman4020
Thanks, is there a place online where i can find diagrams like that? And do you happen to know where the mailn fuse is located?
Old Oct 26, 2009 | 01:58 PM
subford's Avatar
subford
If we are talking about the 1989 truck then it does not have a main fuse.
It uses fuse links.
It has some fuse links coming off the battery side of the starter solenoid and two down (Ignition & O2) on the drivers inter fender in the harness just about 6 inch before the big round firewall plug.
Old Oct 26, 2009 | 02:09 PM
subford's Avatar
subford
Wiring diagram:
Fuel system:
To test fuel pumps ground pin#6 with the key on:
LMPLLC
Dec 13, 2022 09:53 AM
dazedandcofused
Aug 9, 2021 09:25 AM
FordFanatic99
Modular V10 (6.8l)
Dec 29, 2015 09:16 PM
bigwillisF150
Oct 12, 2015 04:37 PM
86oldschoolford
Apr 30, 2015 07:23 PM
