Fuel pump or tank selector valve?
Old 04-13-2010, 06:56 AM
subford's Avatar
subford
subford is offline
Originally Posted by jaytorino
yea my boost pump is working I got under there and started checking all lines for any kinks or something out of place and it all looks good from what i can tell
If you know the boost pump is putting out 8 PSI in the rear than you may have a bad Selector Valve on the Frame.
Old 08-12-2010, 08:17 PM
dybeepvw's Avatar
dybeepvw
dybeepvw is offline
Is the float or sending unit for gauge in this assembly or separate; my rear tank is filling the front tank also, but gauge shows empty all the time on front tank. the truck is 1993 F150 with 300 six engine and 5 speed 2wd and runs fine on both tanks other that the fuel transfer problem; I can smell strong gas odor when running off rear tank.
Old 08-12-2010, 08:58 PM
subford's Avatar
subford
subford is offline
The gauge sending unit is separate.
Sounds like you have a bad FDM in the front tank.
Old 08-12-2010, 09:05 PM
dybeepvw's Avatar
dybeepvw
dybeepvw is offline
So if I am running off rear tank and it is filling the front I need new FDM for rear tank. Thanks for the nice picture's, it does help.
Old 08-12-2010, 09:10 PM
subford's Avatar
subford
subford is offline
No then you would need one for the front.
Old 08-12-2010, 09:15 PM
dybeepvw's Avatar
dybeepvw
dybeepvw is offline
10-4 on that. Thanks again
Old 08-24-2010, 01:49 PM
jasoncrbtr's Avatar
jasoncrbtr
jasoncrbtr is offline
1994 F 150
I have a 94 F150 5.8 that is leaking gas out of the front tank and crossfilling from the rear tank to the front. From what i gather i have a bad FDM in the front tank. The truck runs fine off of the front tank. Will the bad FDM cause the front tank to overfill and leak? Will the truck still run ok with a bad FDM?
Old 08-24-2010, 05:43 PM
subford's Avatar
subford
subford is offline
jasoncrbtr,
Yes to both questions.
Old 09-04-2010, 03:22 PM
captwdhall's Avatar
captwdhall
captwdhall is offline
my '96 F-150 I6 is doing the same thing. rear tank is filling the front, and it sometimes wont start on the front tanks. What is the fuel delivery module? Is that a fancy way of saying fuel pump assembly? Cant find anything online for FDM. Tips for replacement?
Old 09-04-2010, 07:35 PM
subford's Avatar
subford
subford is offline
Yes you can call it the fuel pump assembly.
Old 09-04-2010, 07:51 PM
captwdhall's Avatar
captwdhall
do you have to replace the entire thing, or just a part of it. The motorcraft pump is $450
Old 09-05-2010, 06:15 AM
subford's Avatar
subford
subford is offline
No you do not have to replace the entire thing, just the fuel pump assembly.
Just this, about $150 at O'Reilly Auto Parts:
  #28
Old 09-05-2010, 06:30 PM
urhstry's Avatar
urhstry
urhstry is offline
If I can ask a question as part of this thread.... my 90 f-150 doesn't have voltage at either pump. Front tank is on the ground.... relay in engione compartment kicks on....what do i check next? I took the tank switch out but I don't know the pins to check voltage there. Where do i go from here?
  #29
Old 09-05-2010, 06:46 PM
subford's Avatar
subford
subford is offline
What relay in engine compartment kicks on?
EEC Power Relay or Fuel Pump relay?
  #30
Old 09-05-2010, 09:28 PM
urhstry's Avatar
urhstry
urhstry is offline
That would be the fuel pump relay. Truck sat for two years and I am trying to revive it. 2WD, 300-6, auto.
Quick Reply: Fuel pump or tank selector valve?
