gear ratio
Old Oct 25, 2009 | 05:23 PM
crazer42's Avatar
crazer42
gear ratio
i have a question to something i was just wondering about. if i had 4.11 rear end and changed it to 3.73, would it change my speedometer reading
Old Oct 25, 2009 | 05:46 PM
rbaker6336's Avatar
rbaker6336
Yes it will,you will be running faster than speedo registers
Old Oct 25, 2009 | 07:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, it will not change the speedo reading. The speedometer is reading the speed of the rear axle. The only thing that will change the axle speed relative to ground speed is to change tire size. Changing the axle ratio will change the engine speed relative to ground speed, but it will not affect the speedo.
