dana 44 ujoint help
Old Oct 25, 2009 | 04:18 PM
cyclospot's Avatar
cyclospot
dana 44 ujoint help
I need to replace a u joint on a d44 from a 78 ford 150 what seals do I need to replace or does someone have a exploded veiw so I can order the right parts? So far I think I need-
- inner shaft seal
- outer shaft slinger
- front cover gasket
Is bronco graveyard the best place/price to get these parts?
thanks
Old Oct 25, 2009 | 05:58 PM
mark a.'s Avatar
mark a.
I wouldn't mess with the inner axle seals unless they leak. It's a big job to replace them. You won't need a pan gasket. The axles slid onto the center section. Make sure to check your spindle bearings.
Old Oct 25, 2009 | 09:46 PM
cyclospot's Avatar
cyclospot
d44 ujoint replace
there was some fluid coming out the axle tube. With the ujoint bad it wobbles a lot. Does that mean I need to change the inner seal?
Old Oct 25, 2009 | 11:46 PM
Ford6.02005's Avatar
Ford6.02005
Oil coming out of tube means you will need to replace inner seal-this requires removal of both side axles,inspection cover,and differential case.Carrier bearing caps are stamped from Dana-be sure to reinstall caps on same side and same way they were removed! Side gear in differential case supports inner end of axle and spindle/needle bearing supports outer end-seal does not support axle.
Old Nov 1, 2009 | 01:34 AM
cyclospot's Avatar
cyclospot
Thanks for the replies. I already replaced the u-joint and the new seals on the hub side. After looking at the new ones I could probably got by with the old. I checked the fluid and it was full so I will just keep an eye on it before I tear it down again. Pretty easy to change a u-joint. That inner seal sounds fun. I found a diagram on danas website. Lots of good info there. One more question. Does the rubber seal, (block vee)thats what dana calls it, go on with the point facing toward the lock out? Its the smaller seal next to the needle bearings?
Torky2
1978 - 1996 Big Bronco
Jul 30, 2011 06:27 PM
jdv19
23
Oct 23, 2009 06:41 PM
77f2504by4
May 18, 2008 12:18 PM
Jared Putz
17
Nov 10, 2003 03:19 PM
KJKozak2
Jan 16, 2003 08:58 PM
