angle pinion
Old Oct 25, 2009 | 10:57 AM
cervantes's Avatar
cervantes
angle pinion
does anyone know what degree the drive shaft should be and how to shim it what kind of material are the shims
Old Oct 25, 2009 | 11:22 AM
70_RangerXLT's Avatar
70_RangerXLT
IIRC, the angle should be between 1.5 and 3 degrees (somebody correct me if I'm wrong).
To measure it, you'll need either a bubble protractor or angle finder.
The shims are usually made of aluminum, and they would be inserted between your springs and the spring perches on the axle.
Here's a link, that I hope won't be pulled: Leaf Spring Axle Shim I just posted it to give a little more info. I know there are lots of places that have these, in fact, probably one of the FTE sponsors.
Old Oct 25, 2009 | 11:43 AM
lew52's Avatar
lew52
You will need an angle finder , ussaly 3-5 deg neg (rear end down) from the drive shaft angle, depending if you have traction or ladder bars ... Aluminum shims 2 deg per shim ... Lew
