16.5" rims
Old Oct 23, 2009 | 11:48 PM
Barty88's Avatar
Barty88
16.5" rims
I am finding out that these size rims are an extinct breed the hard way. I bought a 1983 F-250 because the tires on it were almost new. They are 33 16.5 12.50. So the rims are obviously (or need to be) 16.5 ... I have a hole that was repaired by a small dime sized weld on the inside of one of these that has a super slow leak. Can this be reliably repaired by a good welder? I cant find these damn rims ANYWHERE without going to site that charge $200+ for new ones in the old style. I cant find them at any junkyards, anyone have any ideas? My last resort may be to now go buy 2 16" tires for my stock rims and try to get them in a bigger size to at least come close to the 33's, maybe put two on the front and the other 2 33's on the back?
Old Oct 23, 2009 | 11:53 PM
Franklin2's Avatar
Franklin2
Is the damaged wheel aluminum? And it leaks were it was welded? If it has just a few little pinholes in the weld, I would take the tire off and smear jb weld over the weld on the inside of the rim.
It probably can be welded again, but it's hard to find someone who will take the liability working on a wheel.
Old Oct 24, 2009 | 08:13 AM
bashby's Avatar
bashby
+1 on JB weld, but I prefer the JB quick, sets up a lot faster
Old Oct 24, 2009 | 09:12 AM
brett_d's Avatar
brett_d
I agree on the JB weld. Don't forget to rough it up with some heavy grit sand paper, clean with a degreaser, then JB weld it up and hope for the best!
Old Oct 24, 2009 | 05:40 PM
cadunkle's Avatar
cadunkle
You can get 16.5" steel rims for $100-$150. If you want for real cheap then keep an eye on Craigslist. Honestly though I'd either have it welded again (properly) or do the JB weld thing on the inside.
Old Oct 24, 2009 | 06:24 PM
Eddiec1564's Avatar
Eddiec1564
I used some RTV once on a weld seam leak, that worked too. Years ago I got a set of 16.5 rims and almost got rid of the stock 16 rims. Luckly I didn't!
Hedgehog
Jan 20, 2019 06:12 PM
chrismanjoa
Feb 20, 2012 08:08 PM
HateTank
22
Mar 29, 2007 02:07 PM
rallyman
Mar 16, 2005 03:19 PM
Oaktree
Dec 29, 2003 10:53 PM
