As some of you know my truck has been parked for almost a year.
Got it running today but the ABS light on the dash is on and the brake pedal feels funny?
I had all the relays out from under the hood , are any of them ABS related?
I cant think of anything else Ive touched, they worked fine last time I drove it.
How is the steering? Remember the brakes and steering operate off of the hydraboost system and you have to sometimes troubleshoot 2 systems when there is a brake system problem. Start there and then flush the brake system. It sat for too long Ken.
Your on the money again!
Steering is also squealing.
I cant find a diagram of those relays under the hood?
Looked in the owers manual and theres nothing?
Sorry for my confusion. If we are talking about a 2002 there is no under hood fuse box. Your manual should show the under dash fuse designations and locations.
Yes Ive got info about the underdash , but what are the relays under the hood?
Cant find any info on them?
I couldnt find that #602.
I found it in the manual but I couldnt find where it was?
Upper left corner to the right of #101 and #107. It is mounted horizontally. To the lower left of it is a
vertical mounted circuit breaker that should be silver colored.
