General Automotive Discussion
Mpg calculation
Old Oct 23, 2009 | 11:36 AM
TRAINHORNMAN's Avatar
TRAINHORNMAN
Mpg calculation
Well i have a couple questions/problems.
I want to calculate my MPG
1. I have a 12 inch lift with 42s.. does that mean the odo will be correct the distance i travel? If its really 5 miles, will it show 5 on the odo ?
2. My fuel sending unit is messed up so I never know if i have a lot or little left, I keep it above quarter tank. Does this matter in calculating it?
3. Recently I got 280 miles out of 1 tank. 280 divided by 30 gallon tank = 9.3 MPG ... Does that sound right for that big of a truck?
thank for ur help!
Old Oct 23, 2009 | 12:10 PM
andym's Avatar
andym
If your speedometer is not accurate, your odometer won't be accurate either. You don't need a gas gauge but you do need a working odometer.
What you do is fill the truck up and write the mileage down. Drive it around until you have less than 1/4 tank and fill it up. The distance you just drove divided by the amount of gas you just used is your mileage. If your odometer is off 25% then your mileage calculation will be too.
Old Oct 23, 2009 | 05:34 PM
Sand_Man's Avatar
Sand_Man
Yup, you can't guess about mileage. You need an accurately functioning odometer and a known quantity of gas, or in your case diesel.
Old Oct 24, 2009 | 09:23 AM
TRAINHORNMAN
so heres what im thinkin...
go onto google map. from out distance from point A to point B... lets says google says its 5 miles. Then go drive it.. and see what the ODO says..
then i guess i have to get my fuel sending unit fixed?
Old Oct 24, 2009 | 12:02 PM
galaxie641's Avatar
galaxie641
Actually all you need to do is watch the guide posts, they have the mile markers every mile and on straight 2 lane roads the other posts are usually 1/10th of a mile apart, very easy to do the math as long as you put the truck on 60mph and also time the mile then adjust for how much time it takes above or below a minute to go that mile.
Old Oct 24, 2009 | 07:51 PM
fellro86's Avatar
fellro86
I have found many mile markers to not quite be accurate.. I know some use GPS to do the job of speedo...
Old Oct 24, 2009 | 08:11 PM
powerstroke72's Avatar
powerstroke72
+1 on that. Mine is accurate and has been checked against a calibrated speedo and radar. If you have a GPS like a Garmin or similar, put it up in the truck and go for a drive. If you don't have one, borrow one. You should be able to see how far your speed is off pretty easily. That's also going to carry over to the odometer and your perceived mileage. If the speedometer has never been corrected for the larger tires, you're going to be reading slower on the speedometer than you're actually traveling and you're actual mileage on the truck is going to be off.
Old Oct 26, 2009 | 09:15 AM
TRAINHORNMAN
previous owner told me for every 1 miles you go. ur actually doing 1 and a quarter...?
Old Oct 26, 2009 | 10:09 AM
jimandmandy's Avatar
jimandmandy
9.3 does not sound right for a diesel not towing anything. Forget about the gauge, its meaningless for this. What was the stock tire size? You can find it on the door jam sticker. The odometer correction can be calculated if you know the difference in revs per mile. Tirerack.com lists that number in the tire spec tables.
Jim
Old Oct 26, 2009 | 10:13 AM
TRAINHORNMAN
LT235/85R16/E is what the internet says
Old Oct 26, 2009 | 10:22 AM
TRAINHORNMAN
cant find a calculator that will calculte 42s
Old Oct 26, 2009 | 06:26 PM
galaxie641's Avatar
galaxie641
Calculate half the difference then double the results.
Old Oct 26, 2009 | 08:29 PM
jimbeamalki's Avatar
jimbeamalki
Just have someone follow you down the road in a regular set up car. Go about 10 miles, then compare odometers and see what the difference is.
Old Oct 27, 2009 | 12:31 PM
TRAINHORNMAN
ahh that makes sense
Old Oct 27, 2009 | 03:32 PM
Nitramjr's Avatar
Nitramjr
Isn't there a way to check/change the odometer calibration by holding in the trip odometer button at startup? I know on my truck if I hold in the button, turn on then start the truck, then release the button it gives me a code on the odometer. IIRC you have to know the distance per single tire rotation to recalibrate to the correct code. Someone please tell me I didn't dream this....
Otherwise, I'd go the GPS route. Run the truck at various speeds (say 30, 60, 75 mph) on the speedometer and compare the speed on the GPS. The difference should be a constant percentage - if not take the average. Use this difference to adjust your miles traveled. If your speedo reads fast, adjust your miles traveled down by that percentage and vice-versa.
You could do the same thing using mileposts but use a bunch of them in a row. Individual mileposts aren't too accurate but they average out to be dead on.
As for the mpg calculation - the only accurate way is miles traveled divided by gallons required to refill the tank (assuming you started full). Individual tanks could be off some so average a few to get a more accurate number. Keep a running total of miles driven (adjusted for the speedo error) and the total gallons burned.
Other than for maybe telling you your tank is empty - forget about using the gas gauge. They are useless for mileage calculations.
