FPR ON 97 psd
Old Oct 22, 2009 | 10:50 PM
ford pride's Avatar
ford pride
FPR ON 97 psd
can i run bb with stock injectors/ superchip programer,cold air intake,3in. downpipe,4in. exuast 4.11 in rear ,gutted ebv and custom built air inlet on charge side of turbo
Old Oct 22, 2009 | 11:05 PM
Talyn's Avatar
Talyn
Check your Fuel pressure on the schrader valve first.
Its on the side of the FPR.
Use a junk tire gauge or something like that.
dont use a digital one. fuel comes out of the hole.
55-70 is good and doesn't need bb mod.
Old Oct 23, 2009 | 08:49 AM
Neal 97 250's Avatar
Neal 97 250
Yes you can run the bb with that. You can run it stock if you want.
Like Talyn said check your pressure first. i use a stick style of gauge. The one that pushes the rod out. It will get fuel in it but that style gauge it doesn't hurt.
You do not want to exceed 80 psi. Mine had 55 before I shimmed it and 75 after I shimmed it. All trucks are different so check your pressures.
Old Oct 23, 2009 | 10:24 AM
dixokai's Avatar
dixokai
I'm running the BB basically stock. 45 lbs before and 65 lbs after. It did seem to change throttle response some. Cheapest mod I have ever done that actually seemed to make a difference.
Old Oct 23, 2009 | 11:07 AM
Talyn's Avatar
Talyn
Yea. BB is good mod. And you can get one from the neighbor kid for free.
