EGR valve sensor and TPS sensor
Old Oct 22, 2009 | 11:37 PM
andy316's Avatar
andy316
I did a little bit of research on the site and couldn't quite find the solution to my problem. Im throwing two codes. 1. EGR valve sensor below minimum voltage. 2.TPS sensor below minimum voltage. I have been fussing around with my volt meter a little bit and i came up with some frustrating results. I am only getting a steady .35 volts at the EGR valve sensor, when it sould be 5, and nothing at the TPS sensor. I found the same color wires from the EGR sensor on the main harness connector and back probed them. I am only getting a steady .46 volts right at the harness. I checked all the fuses in the engine compartment for the hell of it and thay are all fine. Now i cant figure out where to go from here. Any ideas??
Old Oct 22, 2009 | 11:54 PM
94XLT5.0's Avatar
94XLT5.0
My truck was throwing some kind of TPS code and I just replaced it. Light hasn't been on since, and I noticed the difference when I drove it. They aren't that expensive.
Old Oct 23, 2009 | 08:46 AM
subford's Avatar
subford
One of the sensors that use the 5 Volt supply may be bad or the wiring to the sensors.
The sensors:
1. TPS
2. EVP
3. MAP
Or the 5Volt supply is dead in the computer.
Also check that you have power to pins #1, 37 & 57 and a good ground at pins #40 & 60.
37 & 57 with the key on.
The 5 Volt supply in the computer is wired something like this (J1 is the big PCM computer plug):
Old Oct 23, 2009 | 02:34 PM
andy316's Avatar
andy316
Thanks for the helpful info. I will check those out and see what i come up with. Wiring is one of my downfalls, its helps to have some other input
f100beatertruck
15
Dec 12, 2023 01:53 PM
BigB1975
Feb 28, 2014 07:35 PM
delano79
Aug 30, 2011 08:36 PM
Critter183
Sep 10, 2007 12:15 PM
tapenick
Aug 15, 2002 11:56 PM
