Where to look for a used RV trailer?
Sent you a PM but am also going to post the PDI list here as well in case someone else might be able to use it. Sorry if it is a little long!
Pre Delivery Inspection
Propane System
__ Fill LP Tank
__Check System For Leaks _____” W.C. Pressure For ____ Mins
__Check Running Pressure (11” Running)
__Light Off Water Heater and run to temp
__Cool reefer down to temp
__Light off stove and oven
__Check for OPD certified tanks (Towable units)
Exterior
__Check entry step operation
__Check for dents and damage
__Check window operation and seals
__Check roof seals and condition
__Check roof rack and ladder
__Check all trims and moldings
__Check all exterior lights
__Check paint and decals
Interior
__Check sofa and chairs for operation and condition
__Check window valances for condition/operation
__Check cabinetry for condition and operation
__Check drawer guides and travel locks
__Check countertops for scrapes and scratches
__Check all floor coverings
__Check bed and helper struts for operation and condition
__Check dinette for operation and condition
Plumbing system
__Check all drain lines and “P” traps
__Check all levels on monitor panel
__Check sinks, tub, toilet and shower
__Fill fresh water tank
__Pressure check system with water pump & “Leak check” system
__Fill all holding tanks and check for leaks
__Dump holding tanks
Misc
__Winterize as needed
__Check all keys and tags
__Lube all locks
__Write down appliance numbers
Electrical systems
__Polarity check all110v outlets
__Check all interior lights
__Check reefer operation (amp check)
__Check converter/inverter system
__Check all breakers and fuses
__Check A/C operation
__Install, check or replace batteries as needed
Added Equipment
__Check satellite system for operation with test TV
__Check condition and operation of awnings
__Check for awning rod and crank handle
__Check TV, DVD and VCR operations with remotes
__Check slide out operation and seals
__Check microwave oven (heat water)
__Check TV antenna and booster with test TV
__Check radio and CB operation
__Check solar panel operation
__Check leveling system
__Run generator and test with load
Motorized units
__Test drive and check fuel
__Check backup monitor system
__Check all dash gauges
__Check dash A/C output ____Deg
__Check dash heat output _____Deg
__Check seat belt operation
__Check drivers and passengers seat operation
__Check cruise control (on test drive)
__Check all fluid levels
__Check brakes and steering (on test drive)
__Mileage _____________
Safety Items
__Check fire extinguisher
__Check smoke alarm
__Check CO and LP detectors
__Check safety chains (towable units)
__Check break-away (towable units)
__Check tire pressure and condition of all wheels and tires (including spare)
__Torque all lug nuts
Propane System
__ Fill LP Tank
Exterior
Interior
Plumbing system
Misc
__Lube all locks
Electrical systems
Added Equipment
Motorized units
Safety Items
__Check smoke alarm
Thanks for the info Mike and yes, I would definitely like a copy of that checklist. I will send you a message (he says with confidence like he knows what he's doing) with my email address. By the way you live in a beautiful area of the country. My wife has lived in the Medford area before and still has family there.
Oh, one question I thought of yesterday……generators. How common is it for a generator to be built into the trailer? I see a lot of generators hanging on rear bumpers. A friend of mind had his stolen off of his rear bumper. I'd like to get something with a generator built into the chassis.
Thanks
Thanks
Karl Aube
General Diesel Discussion
17
05-07-2009 02:35 PM
07EXPYEL
38
10-08-2008 09:40 AM
