Sponsored by: Auxito
4x4 not engaging
Old Oct 22, 2009 | 06:02 PM
Builder123's Avatar
Builder123
4x4 not engaging
There are a lot of threads on this but here's something that might narrow it down from the GEM, dif motor, switch etc. When I turn the 4wd switch to 4 high (in park, brake on) nothing happens. No click, no dash light, nothing. Same thing for 4 lo in N brake on. If I turn the truck off and put the switch to 4h and start the truck the light will come on and 4wd will engage and it will be fine for a few times and then stop working again. During this time it will also engage in 4 lo like it's supposed to. I'm thinking the motor is going and not the GEM unit.
Thoughts? As usual your help is appreciated.
2003 4x4 5.4 114,000
Old Oct 22, 2009 | 08:33 PM
De-von Ford trucks's Avatar
De-von Ford trucks
4wd not engaging
the 4wd is not suposed to be ingaged until the truck is shifted into neutral. idk why but my dad does it and my grandpa does it none of their 4wd have ever had any problem, try putting it in neutral and see if it helps
Old Oct 22, 2009 | 10:05 PM
Chrisholmz's Avatar
Chrisholmz
I have an old 97 with the same drivetrain. In mine, 4hi only ingages in neutral or drive. 4lo only engages in neutral. 4hi is suppose to be 4wd on the fly.
Old Oct 23, 2009 | 03:10 PM
Builder123's Avatar
Builder123
When it's working properly 4H engages on the fly but I choose not to because it can bend the fork in the transfer case and actually had to have it repaired because of engaging on the fly. 4H also engages in park when working properly or at least it always has before. Also I tried Park, Neutral, Drive, still nothing until I shut off the truck put it in 4H, Park, brake on and start it.
Old Oct 26, 2009 | 08:00 PM
De-von Ford trucks
4x4
sorry dude if the neutral thing didnt work then i dont no what to tell ya
Old Oct 27, 2009 | 10:14 AM
Builder123's Avatar
Builder123
No Worries. I finally found a thread with the same symptoms and it sounds like the transfer case motor. Thanks for the reply though.
Old Jul 8, 2010 | 10:21 AM
Builder123's Avatar
Builder123
FYI the Transfer case motor was the problem. Real tough to diagnose as the problem was so intermittent. Thanks all for the help.
magyar02
1983 - 2012 Ranger & B-Series
Jul 6, 2014 01:59 PM
w74bronco
Feb 9, 2014 12:40 AM
EastSideTriton
1997 - 2003 F150
Jul 23, 2013 07:29 PM
95FordTruck02
1978 - 1996 Big Bronco
May 26, 2011 08:26 PM
mengonij
Nov 16, 2009 10:26 AM
