Engine shaking while driving
Old Oct 22, 2009 | 05:00 PM
bma1977's Avatar
bma1977
I have a 96 F250 with a straight 6 in it and a 5 speed. When I am driving in about any gear on a light pedal the engine shakes and the truck bucks, like it is dropping a cylinder. As soon as I push down on the gas a little more it clears right out and runs great. I have replaced the plugs, wires, cap and rotor, the fuel filter and air filter, and also the IAC motor trying to figure this out. Any ideas on what to try next? I have also checked for vaccum leaks and did not find any.
PLEASE HELP
Old Oct 22, 2009 | 05:10 PM
Volvo92906's Avatar
Volvo92906
engine mounts?
Old Oct 22, 2009 | 06:39 PM
bma1977's Avatar
bma1977
I don't think so it is misfiring for some reason...
Old Oct 24, 2009 | 09:17 PM
bma1977's Avatar
bma1977
No ideas from anyone??
Old Oct 24, 2009 | 09:27 PM
wolfsmurf's Avatar
wolfsmurf
sounds like a possible bad tps. there is a way to check it using an ohm meter. prolly find the how to on here somewhere. anyone have a link? i had them and had to wipe windows cuz of a dammed hijacker.
Old Oct 28, 2009 | 03:34 PM
awkoop's Avatar
awkoop
Valve problem maby?
Old Oct 28, 2009 | 04:25 PM
andym's Avatar
andym
You have a laundry list of stuff to check out first.
- What's the fuel pressure at idle? Does it jump to about 60 when you take the vacuum line off the FPR?
- Pull the codes?
- What does a vacuum gauge look like if you attach one?
- When was the last tune up, including all filters and ignition parts?
- What's the timing set at? (unlikely to be the direct cause but it would be good to know)
Old Oct 28, 2009 | 04:53 PM
12engine's Avatar
12engine
PLEASE HELP
same thing happened to me. turns out I needed a valve job. clyinder #2 was dead because of it. same motor as you too.
Old Oct 29, 2009 | 02:23 AM
BigSix1's Avatar
BigSix1
Mine developed a slight stumble, only at approx. 1,700 RPM, after I disconnected the battery, which wiped the memory of the ECU. But that is supposed to clear up after a certain number of drive cycles.
Lots of good advice here, re: codes, etc....
Good luck.
Old Oct 29, 2009 | 05:14 AM
TexasGuy001's Avatar
TexasGuy001
Maybe it just needs a tune up. I have had some vehicles run similarly when the cap/rotor and plugs were burned down to nothing.
I agree with checking the codes.
Phillupj23
3.8 & 4.2L V6
Aug 4, 2015 06:32 PM
craziejoker
Nov 9, 2013 07:12 AM
Blmorre
Dec 28, 2012 01:37 PM
Mctod22
Jul 31, 2011 10:50 PM
BroncoBoss351
1978 - 1996 Big Bronco
13
May 13, 2006 12:37 PM
