wiring
Old Oct 22, 2009 | 08:04 AM
rustyolford's Avatar
rustyolford
wiring
i have a 88 f150 and one day the rear antilock light came on and my radio quit working and today my windshield wipers quit any suggestions
Old Oct 22, 2009 | 08:07 AM
wolfsmurf's Avatar
wolfsmurf
fuses would be a good place to start but first. when did this all start?
Old Oct 22, 2009 | 08:17 AM
rustyolford
checked fuses and it started about 3 days ago
Old Oct 22, 2009 | 08:24 AM
wolfsmurf's Avatar
wolfsmurf
do you drive it everyday? how far have you driven it since this started? could be a low voltage problem.
Old Oct 22, 2009 | 08:40 AM
rustyolford
yes i drive it everyday its running normal just those problem just popped up outof the blue
Old Oct 22, 2009 | 08:51 AM
wolfsmurf's Avatar
wolfsmurf
just a shot in the dark here but when an alternator is bad the truck starts shutting off everything electrical to keep the engine running. the engine is the last thing to shut off......could be it isnt putting out the 13.5+ it is supposed to.
Old Oct 22, 2009 | 08:59 AM
rustyolford
that could be possible because there is a wining noise from the engine just thought it was a belt
Old Nov 16, 2009 | 10:55 PM
BigRed Truck's Avatar
BigRed Truck
I had the same problem. I finally got fed up and wiggled under the steering column. I had the key in the ignition and the radio turned on. I finally traced it back to a relay attached to the steering column. The relay was loose and probably wasn't grounded. I snapped the relay back onto the steering column and all is well.
