OH MY GOD!!!!Holy Sh%$
#32
I havent done much research on this yet but have seen mention of it in this thread. Is a upgraded valve body something to be considering and why? Am I going to blow my tranny? Keep in mind I wont be trying to spin the tires.. ( I dont think,lol)Just dont want a problem if I can prevent it...And then would I have to have jody change the tunes because of it? Could he send me "upgraded" tunes w/ the f6 or would he need it?
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
#33
I am sorry to hear your troubles. We can help with whatever issues you are having. It sounds like you have a valve body upgrade and it wasn't tuned for it. Or the tunes you got have too little pressure for your stock trans. Sometimes underlying issues with transmissions don't rear it ugly head until you add power to them. That's why most guys do a valve body or beefier trans. Especially if they tow a lot. If you have a stock trans Jody has to increase line pressures as needed as you go up in power so you don't get the slipage. Sounds like you don't have enough to keep it from slipping in the 80 E.
Its going to be hard to figure out since gos ordered it for you. But we can try by order date.
We do not send to Canada via UPS or FedEx. We only use USPS and since this is a warranty exchange you should NOT be charged again for duty fees.
Please give us a call so we an get your chip set up correctly. 828-221-0076.
Diane
Diane
#34
So I was able to take the truck out for a 45 mile drive today...Wow..The lie o meter that usually says 15 mpg now says 23 mpg in 80E..Its normally off by 1-2 mpg so even at 21 mpg is insane with more power...I also uploaded the drive thru tune trial and it took me all of 5 minutes to do because I had to read the instructions...Also about a upgraded valve body..What exactly will this do?Someone said firmer shifts..The shifts right now are perfect,they dont slam but are firm,I dont want to ruin that..Keep in mind I only have 80 e right now...Will this extend the life of the tranny even if there wasnt a tuner in it?Just trying to justify ever doing this upgrade...I do plan on having this truck for years to come,so if this can make the tranny last even longer great..It has 80000 easy non towing miles on it from previous owner ,I have a 9000lb camper and tow ocasionally,so it wont be doing heavy hauling alot..The vb upgrade looks relatively easy to do and I have to change the tranny fluid soon so I may as well do it then if I do it...Anyways ,thank you Jody!!!
#35
Diane
Diane
#36
Personally, I think that and the 6.0L cooler are essential if you're towing. Just my (not so) humble opinion.
EDIT: Here are a couple graphics describing what the kit does:
