There should be some little gears that are made out of Teflon, those might be stripped out. Happened to my old mans 85 f250. They should make a repair kit of some sort for it.
If that's the problem the motor to the window should still run but the window won't or intermittantly moves.
Those little plastic things are:
Window Regulator gear plugs(3)
Autozone part # 74410 $7.99
cheap fix, getting the regulator out is the fun part.
