front leafspring help
Old Oct 20, 2009 | 01:18 PM
yme450's Avatar
yme450
Ok i narrowed it down to two sets. i dont plow but i do a lot of towing and my stock front springs are way past do to be changed.any help would be great.does anyone now the xcode spring rate. thanks John <TABLE><TBODY><TR class=remove><TD class=attribute-name>
</TD><TD class=item>Remove <HR></TD><TD class=item>Remove <HR></TD></TR><TR class=image><TD class=attribute-name>
</TD></TR><TR class=larger-image><TD class=attribute-name></TD><TD class=item>large image</TD><TD class=item>large image</TD></TR><TR class=threedvo-model><TD class=attribute-name></TD><TD class=item></TD><TD class=item></TD></TR><TR class=brand><TD class=attribute-name>Brand</TD><TD class=item>Tuff Country</TD><TD class=item>Pro Comp Suspension Systems</TD></TR><TR class=part-no-man><TD class=attribute-name>Manufacturer Part Number</TD><TD class=item>28290</TD><TD class=item>22210</TD></TR><TR class=part-type><TD class=attribute-name>Part Type</TD><TD class=item>Lift Springs</TD><TD class=item>Lift Springs</TD></TR><TR class=product-line><TD class=attribute-name>Product Line</TD><TD class=item>Tuff Country EZ-Ride Leaf Springs</TD><TD class=item>Pro Comp Lifted Leaf Springs</TD></TR><TR class=part-no-sre><TD class=attribute-name>Summit Part Number</TD><TD class=item>TFY-28290</TD><TD class=item>EXP-22210</TD></TR><TR class=price><TD class=attribute-name>Price</TD><TD class=item>
  • $115.95
  • $124.95
</TD></TR><TR class=add-to><TD class=attribute-name>+ to Cart/Wishlist</TD><TD class=item><INPUT style="BORDER-RIGHT-WIDTH: 0px; BORDER-TOP-WIDTH: 0px; BORDER-BOTTOM-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00__CtlContentPlaceHolder_ctl07__CtlCartButt on class=cart-button title="Click here to add TFY-28290 to your shopping cart." src="http://www.summitracing.com/images/system/sys_01_button_addtocart.gif" type=image name=ctl00$_CtlContentPlaceHolder$ctl07$_CtlCartBu tton> <FIELDSET>
</FIELDSET>
+ wishlist <INPUT id=ctl00__CtlContentPlaceHolder_ctl08__CtlWishlist X type=hidden name=ctl00$_CtlContentPlaceHolder$ctl08$_CtlWishli stX> <INPUT id=ctl00__CtlContentPlaceHolder_ctl08__CtlWishlist Y type=hidden name=ctl00$_CtlContentPlaceHolder$ctl08$_CtlWishli stY>
</TD><TD class=item><INPUT style="BORDER-RIGHT-WIDTH: 0px; BORDER-TOP-WIDTH: 0px; BORDER-BOTTOM-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00__CtlContentPlaceHolder_ctl09__CtlCartButt on class=cart-button title="Click here to add EXP-22210 to your shopping cart." src="http://www.summitracing.com/images/system/sys_01_button_addtocart.gif" type=image name=ctl00$_CtlContentPlaceHolder$ctl09$_CtlCartBu tton> + wishlist <INPUT id=ctl00__CtlContentPlaceHolder_ctl10__CtlWishlist X type=hidden name=ctl00$_CtlContentPlaceHolder$ctl10$_CtlWishli stX> <INPUT id=ctl00__CtlContentPlaceHolder_ctl10__CtlWishlist Y type=hidden name=ctl00$_CtlContentPlaceHolder$ctl10$_CtlWishli stY></TD></TR><TR class=additional-info><TD class=attribute-name>Additional Info</TD><TD class=item>Drop Ship <FIELDSET>
This part is normally shipped directly from the manufacturer / Supplier.
</FIELDSET>
</TD><TD class=item></TD></TR><TR class=warnings><TD class=attribute-name>Important Info</TD><TD class=item></TD><TD class=item>Oversize <FIELDSET><LEGEND id=ctl00__CtlContentPlaceHolder_ctl14__CtlShipping ChargeFloatingLayerMessage__CtlFieldsetLegend>Warn ings</LEGEND>
The part EXP-22210 has an additional shipping charge of $7.50 per item due to its large size and/or weight.
</FIELDSET>
</TD></TR><TR class=space><TD class=attribute-name></TD><TD class=item></TD><TD class=item></TD></TR><TR class="attribute different"><TD class=attribute-name>Description</TD><TD class=item>Suspension Lift, 4WD, 2.0 in. Front, 0.0 in. Rear, Ford, F250, F350, V-10, Diesel, Kit</TD><TD class=item>Lift Spring, Leaf-Style, Front, Black Powdercoated, Ford, Excursion, F-250, F-350 Super Duty Pickup, Each</TD></TR><TR class=attribute><TD class=attribute-name>Bushing Color</TD><TD class=item>Black</TD><TD class=item>Black</TD></TR><TR class="attribute different"><TD class=attribute-name>Bushing Material</TD><TD class=item>Polyurethane</TD><TD class=item>Rubber</TD></TR><TR class="attribute different"><TD class=attribute-name>Bushings Included</TD><TD class=item>No</TD><TD class=item>Yes</TD></TR><TR class=attribute><TD class=attribute-name>Leaf Spring Width (in)</TD><TD class=item>-</TD><TD class=item>-</TD></TR><TR class=attribute><TD><HR></TD><TD class=colspan colSpan=2><HR></TD></TR><TR class=attribute><TD class=attribute-name>Notes</TD><TD class=item>-</TD><TD class=item>-</TD></TR><TR class="attribute different"><TD class=attribute-name>Progressive Rate Spring</TD><TD class=item>No</TD><TD class=item>Yes</TD></TR><TR class=attribute><TD class=attribute-name>Quantity</TD><TD class=item>Sold individually.</TD><TD class=item>Sold individually.</TD></TR><TR class="attribute different"><TD class=attribute-name>Spring Finish</TD><TD class=item>Black</TD><TD class=item>Black powdercoated</TD></TR><TR class="attribute active"><TD class=attribute-name>Spring Position</TD><TD class=item>Front</TD><TD class=item>Front</TD></TR><TR class=attribute><TD><HR></TD><TD class=colspan colSpan=2><HR></TD></TR><TR class="attribute different"><TD class=attribute-name>Spring Rate (lbs/in)</TD><TD class=item>605 lbs./in.</TD><TD class=item>430 lbs./in.</TD></TR><TR class=attribute><TD class=attribute-name>Spring Style</TD><TD class=item>Leaf</TD><TD class=item>Leaf</TD></TR><TR class=base><TD class=attribute-name></TD></TR></TBODY></TABLE>
Old Oct 20, 2009 | 01:39 PM
just another truck's Avatar
just another truck
Your leaf code is listed on the inside of your door i believe listed under SPR, or did I miss understand you, and you are looking for a value?
Old Oct 20, 2009 | 01:42 PM
just another truck
This is some of Stewarts notes
Again these are estimates and for Excursions only if you want them more accurate then weigh your truck get my Excel file and the work with real data.
So with that said here it is:
Front axle weights used are 4080, & D code springs for the PSD and 3680, & C code springs for the V-10
Application---Code---Capacity-----Rate----Travel --------- V-10 ----- PSD
--------------------------------- /spring---to Max Cap ----height ----height
--------------------------------------------------------- change --- change
Exc V8 ------- B ----- 4100 ----- 330 ----- 5.02 ---------- -0.25 --- -0.66
Exc V10 ------ C ----- 4300 ----- 350 ----- 5.01 ----------- 0.00 --- -0.37
Exc PSD ------ D ----- 4700 ----- 380 ----- 5.14 ---------- +0.33 ---- 0.00
F250/350 All springs are computer selected
Also the use of a rear sway bar and what size it is package dependant
SD-250/350--- S -----4000 ----- 370 ------ 4.34 --------- +1.22 --- +0.88
-------------- T ----- 4400 ----- 390 ------ 4.63 --------- +1.42 --- +1.11
-------------- U ----- 4800 ----- 410 ------ 4.89 --------- +1.60 --- +1.32
-------------- V ----- 5200 ----- 430 ------ 5.13 --------- +1.77 --- +1.50
F450 -------- W ----- 5600 ----- 450 ------ 5.34 ---------- +2.77 --- +2.52
F550 &350/ DRW with Snow Plow prep Package
-------------- X----- 6000 ----- 470 ------ 5.54 ----------- +2.90 --- +2.68
I hope that helps.
Old Oct 20, 2009 | 02:00 PM
yme450's Avatar
yme450
thanks my springs are u code and no longer hold the weight of the truck.so its time to buy new spring.the pro comp are 430 spring weight.so that would put me in vcode buy your chart thanks.
Old Oct 20, 2009 | 03:18 PM
just another truck
You are Welcome, but it was Stewarts information.. So give him a rep when you get a chance. Have fun with the install
Old Oct 20, 2009 | 03:34 PM
Layson's Avatar
Layson
Get a set of Icon springs. 10x better. Clay at riffraff can get them for you too
sales@riffraffdiesel.com
Old Oct 20, 2009 | 04:19 PM
Stewart_H's Avatar
Stewart_H
Now I understand why you repped me, Pat!
Thanks for that, bro!
Stewart
Old Oct 20, 2009 | 04:48 PM
PaysonPSD's Avatar
PaysonPSD
Pat,
Thanks for posting the spring info. Can only rep one poster per thread so I followed your instructions
Stewart
Reps to you Srewart for the spring info Pat posted.
Old Oct 20, 2009 | 06:40 PM
yme450's Avatar
yme450
how do rep a person
Old Oct 20, 2009 | 06:53 PM
big poppa's Avatar
big poppa
See that heart at the upper right hand corner of your post?? you find the person that you want to rep and click on that and write what you want and send.
Old Nov 26, 2009 | 09:53 PM
housedad's Avatar
housedad
What about Bruce1954?
Old Nov 27, 2009 | 02:26 AM
Stewart_H's Avatar
Stewart_H
Bruce doesn't post here Bion. I wish he did. He was a tremendous resource for me all those years ago back when I was doing my research on the V code, B code upgrade.
I haven't been active over at TDS in years, but I'm pretty sure he's still over there.
Stewart
Old Nov 30, 2009 | 07:18 AM
housedad's Avatar
housedad
I just went over there last night to look up his old post about air bags. He's still there and posting as of yesterday.
Old Nov 30, 2009 | 03:47 PM
Stewart_H's Avatar
Stewart_H
That's good to know!
Stewart
Old Nov 30, 2009 | 03:57 PM
78ihs2's Avatar
78ihs2
I just put the tuff country springs in my 250. The ride is alright with them, I didnt put new shocks on yet that would help I think but its a bit rougher than stock. Also the front sits just barely higher than back now so I'm probably goin to put a 350 block in back.
