fixed my oil cooler
Old Oct 20, 2009 | 07:51 AM
broncxl302's Avatar
broncxl302
fixed my oil cooler
so i posted a thread awhile back saying i had oil in my coolant. and alot of people siad oil cooler seals and o-rings. well i finally did it. it was pretty damn easy. and straight forward. the only thing is them seals and o-rings are expensive. 76 dollars from the local ford dealer. but i havnt seen any oil in my coolant so far. so thanks guys. i hope this help anyone that has the same problem
Old Oct 20, 2009 | 08:11 AM
fifthwheel01's Avatar
fifthwheel01
Hey great work! Can you tell us about the FIX? What was involved, etc. I must have missed your previous post. Thats a fix I haven't heard about yet. I for one would appreciate more info in case I should have to do it.
Old Oct 20, 2009 | 11:09 AM
broncxl302's Avatar
broncxl302
well its pretty staight forward. i got directions from a haynes manual.
you have to drian all your fluids. really well or youll have a nice surprise of radiator fluid all over you when you pull your block heater off.
you need 10m socket or rench to get it off. you to pull off your radiator hose the lower one to get to the fron of the oilcooler. the back is realy plan and simple its all right there where your oil filter plugs in. than once you get it off. i pried mine apart with my hands and a pipe wrench. (its all pressed together)
than i cleaned it all out with soap and water and than let it dry.
put my new o-rings in. than i put a ratchet strap around it and pressed it back together. (becareful doing that makes sure you dont have the ratchet on the heads because it alluminum and it could crack) and than you just put it all back together.
i changed mine because i kept getting oil in my coolant.
unfurtunatly when i looked today at my radiator fluid there was ANOTHer small ring of oil so i dont know if i fixed it. im goin to flush out my radiator again hopping that mabe some was sill in the iono. but its diffanetly worth doing.
sorry for the long discription i hope it helped. if it made sence at all
Old Oct 20, 2009 | 11:55 AM
SpringerPop's Avatar
SpringerPop
It's going to take a while to get ALL the oil to float on top of the coolant in the degas bottle, but you'll know soon enough if you still have the problem.
Did you lubricate the o-rings with anything for re-assembly?
Pop
Old Oct 20, 2009 | 12:01 PM
PaysonPSD's Avatar
PaysonPSD
LINK to vendor who sells a gasket and o-ring kit.
"Complete reseal kit for PSD Engine mounted Oil Cooler.
Our own custom kit we have put together using all OEM parts to completely reseal your leaky oil cooler. Our kit contains EVERYTHING you will need to remove and replace both gaskets and all 4 o-rings."
Kit contents
2-1C3Z6C610BA Thick Green O-rings
2-1C3Z6K649BA Thin Blue O-rings
1-F7TZ6A636AAA Gasket
1-F4TZ6A636A Gasket
Old Oct 20, 2009 | 12:03 PM
rbaker6336's Avatar
rbaker6336
Best thing I found for getting oil out of a cooling system is automatic dish washer soap,it don't foam up like regular soap
This is also Caterpillars recipe
Old Oct 20, 2009 | 01:35 PM
PaysonPSD's Avatar
PaysonPSD
Just found my .pdf copy of oil cooler R&R.
File Type: pdf
Old Oct 20, 2009 | 06:44 PM
fifthwheel01
More great info for my "file 250" thanks guys.
Old Oct 21, 2009 | 03:59 PM
broncxl302's Avatar
broncxl302
yea i looped up all the rings with new motor oil mabe its just that cause i loobed it up pretty good and its barely any in the radiator im gonna do another flush of it and see what happens
