Solenoid/wiring problem??
Old Oct 19, 2009 | 10:27 PM
sainty333's Avatar
sainty333
(86)
After sitting all summer, I finally got around to putting the rebuilt starter and new solenoid back into my truck. After hooking up everything(correctly I thought) I went to hook up the negative battery cable and it arc'd and started turning over. The key wasn't even in the ignition. I have the starter cable on the "M" side of the relay. I have the + battery cable on the "B" side of the relay along with the wire coming from the coil. I have the ignition wire on the "S" terminal(snap on). I also have a wire running from the radio to the "B" side of the relay. (someones fix a long time ago) According to the slip of paper with the solenoid, I have everything hooked up correctly, but I am not sure where to go from here. Ground issue? Ignition issue??
Old Oct 19, 2009 | 10:35 PM
ctubutis's Avatar
ctubutis
Sounds like a defective solenoid; was it made in China? They have a bad
reputation here, go spend $30 at Ford and get a Motorcraft variant.
BUT I don't understand where you talk about a wire from the coil being
hooked up to the B side of the solenoid?
Old Oct 19, 2009 | 10:48 PM
sainty333's Avatar
sainty333
Item Detail | O'Reilly Auto Parts
that is the solenoid, will check the box tomorrow to see where its made.
The coil lead wire i believe its called...2 yellowish/tan wires with a fusible link runs to the battery side connection on the solenoid.
Old Oct 19, 2009 | 11:43 PM
doug1222556's Avatar
doug1222556
Does it look like the one in the picture? Mine looks like this: AutoZone.com | Vehicle Selection | Year.
Old Oct 20, 2009 | 12:15 PM
86bigred's Avatar
86bigred
i agree with ctubutis,defective relay,i use motocraft one's only.
Old Oct 20, 2009 | 04:45 PM
sainty333's Avatar
sainty333
Yep, thats it exactly.
cynestor
13
Jun 14, 2016 10:28 PM
chappys4life
Jun 29, 2012 12:05 AM
TestDepth
Feb 25, 2007 05:49 PM
xfordtech
Sep 12, 2005 12:02 PM
Rosati
Apr 18, 2005 04:54 PM
