need help
Old Oct 19, 2009 | 03:59 PM
mustangmikew's Avatar
mustangmikew
need help
i just put a 69 long block in my 93 f-150 with all the efi on top, i get fire and fuel but it wont fire ,going crazy
Old Oct 19, 2009 | 06:32 PM
Oldguy4's Avatar
Oldguy4
Crank position sensor? correct fuel pressure? These are just a couple of things that the computer needs to get a start condition. You might ask the guys over at the 98 - 96 F-siries and larger forum.
Old Oct 19, 2009 | 08:23 PM
Greg B's Avatar
Greg B
Which engine? We need a little more info. Usually on these older trucks if you have spark and fuel it's a timing issue or firing order issue. I am assuming you are using all of the 93 electronics and compression readings are all good. Cam will determine firing order.
SUPERDUTY_untouchabl
Arkansas Chapter
Sep 21, 2007 06:44 PM
TUCK
Texas Chapter
Dec 1, 2002 06:53 PM
motobub
Exhaust Systems
Nov 15, 2002 05:05 PM
Ginntonnik
1978 - 1996 Big Bronco
Jan 23, 2002 06:09 AM
CRJ900
Jan 18, 2002 04:05 PM
