Fuel tank issue...
Old Oct 19, 2009 | 02:37 PM
strokersace's Avatar
strokersace
Exclamation Fuel tank issue...
When I bought my 95 the rear tank filler neck was removed from the opening and tied up under the truck. I just assumed it was because the truck had a large transfer tank in the bed that was tied into the front. So I reattached everything and used a suction pump to pump the old fuel in there out. Before when switching to the rear tank just to see if it it had fuel, it'd show about 1/2 tank. So got the old junk out and refilled with about 15 gallons of new diesel.
I switched to the rear after filling it, the gauge goes WAY past full (almost back horizontal) But when the front tank is completely full it just goes to full like it's suppose to. I swapped to the rear the other day when running down the road, the gauge went past full, and a couple of miles down the road it started sputtering and running out of fuel. Switched back to the front tank and it picked up and ran fine again.
What is causing my issue in the rear tank? Sending unit failure? Selector valve failure? Not sure what else it could be and would like to have some idea before tearing into it.
Thanks guys!
Old Oct 19, 2009 | 06:36 PM
pjwoolw's Avatar
pjwoolw
I guess that answers the question of why the neck was tied up.
Old Oct 19, 2009 | 06:37 PM
etldak's Avatar
etldak
Sounds like the Selector valve the truck dont care if the gauge works just if the fuel gets there.try switching the lines around to and so you know if its the valve or a pluged line.
Old Oct 19, 2009 | 06:42 PM
etldak's Avatar
etldak
Also a cupple of thing go wroung with the gauges the wireing at the plug at the tank loose.bad sender,and have seen a bad Selector valve do it to. the sending unit wiring runs to s/s before it go's to the gauge.
Old Oct 21, 2009 | 01:24 PM
strokersace
Yep. Sure does.
Thanks etldak. I'll need to try some of that.
Does anybody know what size pickup and return lines these trucks have?
Old Oct 24, 2009 | 12:08 AM
oldbird1965's Avatar
oldbird1965
If it was me I would drop the tank and clean it out. Clean the pickup and blow out the lines. I'm not sure above the selector value but I would think that dirt would screw it up.
Old Oct 25, 2009 | 10:26 PM
strokersace
Thanks Glenn. I'm going to be dropping the tank within the next week or 2. Picked up a new sending unit this weekend for cheap. Going to throw that it. Also going to do what you said with blowing the lines out.
Hopefully that'll fix the issue.
Old Nov 21, 2009 | 09:33 PM
strokersace
Update:
Dug into this issue today and found the problem. It seem that when the auxiliary tank was put in the bed, they completely unhooked the rear tank from the selector valve and hooked up the aux. supply/return lines in it's place. The sending unit wire was also cut in the wiring harness so the gauge would work properly when switched the the aux (rear) tank. Took some time getting everything hooked back up but finally got it done.
So far so good!! Guess I'll keep the extra sending unit and selector valve as spares just in case.
Thanks for the help guys.
Old Nov 21, 2009 | 10:18 PM
95_Dually's Avatar
95_Dually
It is always a puzzle putting the trucks back together after the PO modified them to fit their needs. Good to hear you found the time to get it the way you want it.
Old Nov 22, 2009 | 06:13 PM
strokersace
Yeah, I've never seen an aux tank installed that way. It makes sense why they did it - 100+ gallons in the bed compared to 18 in the factory rear. But why didn't they redo it when the aux tank was removed??? I don't know. But it's right now. I'm going to be adding an aux tank in the bed too but it'll be tied into the front tank. Should ad about 50 gallons there. Plus swapping the rear tank for the 38 gal so I'll have a total on board of over 100 gallons.
Old Nov 22, 2009 | 06:21 PM
1976F250HiBoy's Avatar
1976F250HiBoy
Im not going to compare apples to apples here but similar response from the engine. One of our 9520 4x4 tractors had an operator leave the fuel cap off and went ahead and worked ground that way allowing corn shucks and everything else into the tank. Those shucks eventually wound up in the fuel lines and plagued fuel pressure. check your fuel pressure to make certain your lines are free from debris.
Old Nov 22, 2009 | 06:26 PM
95_Dually's Avatar
95_Dually
Wow, 100 gallons. Please don't ask me to help you pay to fill it up. On the other hand, it should last awhile between fill ups.
Old Nov 22, 2009 | 06:52 PM
strokersace
Refer to post #8 for the cause if the issues. Everything works fine now.
Yeah, not cheap per fillup bot far between them. In the end of a trip, you've still spent the same amount of money on fuel. I don't like having to stop unless absolutely necessary. Traveling thru Montana and Wyoming, there can be some great distances between fuel stops. And it seems like you end up stopping early and more often cause you can't make it to the next large town with truckstop. This way, I don't have to stop ANYWHERE, unless it's to water the weeds in the ditch!
Old Nov 22, 2009 | 06:55 PM
95_Dually's Avatar
95_Dually
I know what you mean about getting fuel early. I am to the age though that I need to stop to water the weeds about the same time I need to fill up. It is also the same time I get another drink, which is probably why I need to water the weeds.LOL
