assembly order
Old Oct 19, 2009 | 10:58 AM
z1121jack's Avatar
z1121jack
assembly order
Can anyone tell me the order in to install rebuild parts in a 351w? I am trying to rebuild . Have installed the pistons crank, rods & bearings But I do not know what to do next.
Old Oct 19, 2009 | 11:06 AM
Conanski's Avatar
Conanski
Get yourself a shop manual.. easily worth the $$.
Old Oct 19, 2009 | 05:25 PM
BucksTrucks's Avatar
BucksTrucks
Cam, oil pump, heads, valve train intake... get a book my man.
Old Oct 19, 2009 | 06:44 PM
z1121jack's Avatar
z1121jack
I will get a book
Old Oct 19, 2009 | 06:58 PM
z1121jack's Avatar
z1121jack
they don't make a shop manual for a 1948 f1 with an '82 comero ifs and a 1984 351w
Old Oct 19, 2009 | 07:26 PM
grumpy46's Avatar
grumpy46
yea they do. it's 3 volumes tho
Old Oct 19, 2009 | 07:59 PM
z1121jack's Avatar
z1121jack
What is a good book to use when overhauling a 351w
Old Oct 19, 2009 | 09:54 PM
Conanski's Avatar
Conanski
Oh that's an easy one....
How To Rebuild Small Block Ford Engines: Amazon.ca: Tom Monroe: Books
Old Oct 19, 2009 | 11:53 PM
doug1222556's Avatar
doug1222556
Where did you get the torque specs for the main and rod cap bolts?
Old Oct 20, 2009 | 12:07 AM
g_k50's Avatar
g_k50
Originally Posted by Conanski
I've got that one. Still need the gray matter between ears.
Old Oct 21, 2009 | 05:39 PM
93F22A6's Avatar
93F22A6
I know for the 302 rod bolts are 27ft-lbs. Well hold I have them on my desktop. Mains for the 351 are 95-105ft-lbs and 40-45ft-lbs is what the chart says. May want to make sure about the rod bolts because we over torqued them and had to get all new ones.
Old Oct 21, 2009 | 06:02 PM
doug1222556
my Chilton's manual says 19-24 ft. lbs. for 1976-77 for the rod bolts, 40-45 ft. lbs. for 1978-86. The mains are 60-70 ft.lbs. for the 76-77 and 95-105 for 78-86. ???
The Hayne's manual just shows 19-24 for the 302 rod bolts, 40-45 for the 351W. It shows 60-70 for the 302 mains and 95-105 for the 351W.
Go figure.
Old Oct 21, 2009 | 11:27 PM
Boba Fett's Avatar
Boba Fett
Totally agree with Conanski... that book is a bible if you are a newbie
