120k Maintenance
Old Oct 19, 2009 | 10:53 AM
mr240's Avatar
mr240
120k Maintenance
My 02 Expy is about to go over 120k. What maintenance should I get done.
Old Oct 19, 2009 | 01:58 PM
bumparker's Avatar
bumparker
I just did my 120k. Transmission flush (every 30k), oil change, rear diff change (positrac needs every 30k with added friction modifier). You should have done coolant at 100k. Fuel filter is up to you, recommended every 15-30k. I'm sure you'll get lots of other recommendations.
Old Oct 19, 2009 | 05:49 PM
alloro's Avatar
alloro
Exactly what you owners manual tells you to get done at this mileage.
Old Oct 20, 2009 | 09:00 AM
mr240's Avatar
mr240
I would of referred to the manual if I had one.
Old Oct 20, 2009 | 09:39 AM
g_k50's Avatar
g_k50
Helm Inc, has owners manuals if you want a paper copy, about 20,
Scheduled Maintaince: http://www.motorcraftservice.com/pub.../02a02mg3e.pdf
Change engine oil and replace oil filter
O Inspect brake pads/shoes/rotors/drums, brake lines & hoses, and parking brake
system
O Inspect wheel ends for endplay and noise
O Inspect engine cooling system and hoses
O Inspect exhaust system and heat shields
O Inspect steering linkage, suspension, and if equipped driveshaft and ball joints
O Inspect tires for wear and rotate
O Replace engine air filter
O Replace fuel filter*
O Replace cabin air filter, if equipped
O Replace accessory drive belt(s) (Villager and Escort)
O Replace PCV valve on all passenger cars and light trucks over 6,000 Gross Vehicle
Weight (See page 5)
O Change automatic transmission/transaxle fluid on all vehicles equipped with AX4S,
4F50N, 4R100, 4F27E. Inspect automatic transmission fluid level on all other
vehicles, if equipped with dipstick. Consult your dealer for your particular
requirements.
O Replace camshaft belt on all 2.0L, 4 cylinder engines (Escort, Cougar, Focus, and
ZX2)
O Replace climate-controlled seat filters (Navigator and Blackwood, if equipped)
O Change manual transmission fluid (Lincoln LS only)
O Lubricate 4X2 wheel bearings (except F-450/F-550)
O Inspect and lubricate 4X2 ball joints (except F-450/F-550)
O Lubricate 4X4 front hub needle bearings (F Super Duty)
O Replace camshaft belt on 4 cylinder engine (2.0L Escape)
O Inspect and lubricate steering linkage (E and F Series, Expedition, Navigator,
Excursion
Old Oct 20, 2009 | 11:50 AM
mr240's Avatar
mr240
Exactly what I was looking for. Thanks for the help.
Old Oct 20, 2009 | 06:06 PM
alloro's Avatar
alloro
You can download a PDF of your owners manual here:
https://www.fleet.ford.com/maintenan...ls/default.asp
CaptainMarvel
1997 - 2003 F150
Mar 19, 2015 12:52 PM
WarrensE350
19
Sep 13, 2014 11:24 AM
Gotanoldtruck
2004 - 2008 F150
Aug 5, 2013 05:53 PM
slovride
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 22, 2013 06:51 AM
cpoer
Jan 8, 2013 05:40 PM
