Need help on rear breaks.
Old Oct 19, 2009 | 10:09 AM
Tim_M's Avatar
Tim_M
The issue is on my 05 F250 PSD, the driver rear break seems to be coated in oil, really the entire inner of the wheel is coated. I am not leaking break fluid so I am thinking it's the axle that is bad, maybe a seal but my knowledge in that area is limited. I looking for suggestions on what to look for before I take in to the dealer, also what to tell the delaer. I still have a little factor warntee left maybe this would be covered?
Also after a driving there is a smell of burning oil comming from that wheel..
Thanks in advance!!
Old Oct 19, 2009 | 11:16 AM
zhilton's Avatar
zhilton
This thread would be best suited in the SuperDuty forum and not the 6.0L. Hopefully a moderator can move this one so that you can get a reply from someone that may have had this issue before.
But to answer you question...that sounds allot like seal is cracked/worn on the end of the axle tube. The smell of burnt oil is the gear lube that's in the rear-end. I'd get that taken care of soon before the rear end runs out of oil and causes even more problems.
Old Oct 19, 2009 | 02:28 PM
Tim_M's Avatar
Tim_M
Thanks I'll post over there.
jazzyndon52
Jan 1, 2015 10:58 PM
tseekins
2009 - 2014 F150
21
Jul 25, 2013 08:13 AM
Brian F100 1960
Aug 17, 2012 07:55 AM
Kuttysark40
All Things Towing
Sep 19, 2004 09:53 AM
