Sponsored by: Auxito
4.6 spark plug wire failures.
Old Oct 19, 2009 | 12:48 AM
Thudpucker's Avatar
Thudpucker
Smile 4.6 spark plug wire failures.
I had the code; "#4 plug wire failure".
I began to shop. Eventually I wound up with a couple Terminal ends for the wires.
I replaced the #4 wire and the problem went away. Then #3 and #5 failed.
I'd guess that all of them will fail eventually.
I put new terminal end on #3 and the problem quit.
The Ford ends rust. The wires are OK at the Distributor, it's just those Rusty terminal ends.
I can't drive it this way. I need some terminal ends.
So...do any of you guys know where I can get some terminal ends?
I've been online to a lot of (MSD, Summit, Moroso, O'reilly's...) places but they want to sell wire sets.
I just want Terminal ends.
Help!
Old Oct 19, 2009 | 08:21 AM
KhanTyranitar's Avatar
KhanTyranitar
The ends should not rust if you use dielectric grease. You need to use genuine Motorcraft wires.
Old Oct 19, 2009 | 02:28 PM
Thudpucker's Avatar
Thudpucker
I'm guessing, since this is a 97, that the wires have been changed. At least once.
I cant find a F mark on the wires so you are probably right.
They have lasted the three years I've owned the truck though.
The wires are good. All measure 7 Kohms or so.
I'll just replace the ends.
