Wooooohoooooooo
Old Oct 23, 2009 | 08:17 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
The other problem you run into is that for the ZF I think you need a Hydraulic clutch, which my 1980 does not have (not even a plate that can be knocked out to install one). So unless your '82 has that, you mght have to do some hacking...
Old Oct 24, 2009 | 12:00 AM
86Stepside's Avatar
86Stepside
Another thing to watch out for is in '92 ford switched to electronic speedo, so there is no provision for the speedo cable if the truck is a 2wd, otherwise on 4wd it goes into the transfer case and in that case it would'nt cause a problem.
Amish65F100
Apr 5, 2017 08:37 AM
mtrosclair
32
Mar 29, 2017 12:00 AM
svemike
53
Oct 19, 2016 12:42 PM
S-10 warrior
Sep 17, 2016 08:05 PM
f-250.4x4.390
Jul 22, 2015 03:12 PM
