Yet another newbie question from me How cold does it need to be to plug my truck in? Is it okay for it to be plugged in all night? Does block heater usage decrease warm up time? I noticed on the couple of somewhat cold nights - 20 deg - we have had the truck takes quite a few miles to warm up.
you can plug it all night. I plug mine in all winter, it will warm up faster oil will by warm and truck will turn over beter, and heat up the cab faster too.
you can turn heat dial to hot and defroster on so heat will escape and help keep the windshield clear as well. Leave on all night is fine or get yourself a heavyduty outdoor timer and you can set for how long as you like,4 hrs or so
Im a newbie ,first winter with a diesel.. But If you are paying the electric I wouldnt plug it in all night. Maybe put it on a timer 1 or 2 hours prior to leaving. 1500 watt heater costs some dollars to run all night.. Someone who knows more correct me if im wrong..
The heater draws around 1000 watts constant. It doesn't go down as the truck warms up. Both my dad and myself have timers installed on the outlets where we plug in. The come on about 3 hours before we usually leave for work. If you get one of those plug in timers, make sure its rated for 15 amps for safety reasons and that you're using at least a 14awg cord or larger (lower number) if your cord is over 20 feet. Some people might think thats overkill on a cord, but I know of one guy who burned his garage down using a small cord. The timers we use are 20amp hard wired Intermatic timers. Lowes and Home Depot sell them.
You can plug in whenever you'd like and 24 hours a day if you want. When electric is free (a.k.a at work haha), I plug in my truck when it dips below 40. At home we usually wait till its 30 or lower.
Also check to make sure that the blades on your plug are clean and that it stays plugged in tight. If the end of the cord on the truck is heating up, you probably have a wire that's partially broken and should replace the plug.
They can be plugged in any or all the time. Our ambulances are plugged in 24/7 but that is because there is no time for warmup, when we leave the bay it is usually full throttle. And the few times the heater has failed it sucked waiting for warm up and trying to get down the road in a hurry.And our ambulances are housed inside. But that is going to use more electricity.
We plug our semi's in during the winter and they are on there own power meter, with 2 trucks plugged in the bill was 40.00 per mth. so 20 bucks per mth. for 14 hrs per. day per trk.
Good idea... I have a PSD 7.3 as well since 99. everytime below zero celcius it's plugged in all night. definatley helps your engine and will increase life.
Nope, you're correct. Ran the numbers once and found out it was costing me about $35 a month to plug the truck in for 7 hours at night 5 days a week, and that was several years ago!
Now I have an outdoor timer and I set it to go off 3 hours before I leave for work. IF its super super cold outside (negative temps) you'll benefit from plugging it in for a longer amount of time.
The amount of electric these things use plugged in is nothing, compared to everything else on them that costs!
If you can afford to buy fuel for the guzzlers ,and afford parts whats a little more expense to make them last longer ?
Money is money, save it where you can. Just because I drive a diesel truck doesn't mean I am going to waste money or have unlimited funds.
Same here Lisa, $35 extra bucks on the bill. Now it's just 3 hours 7 days a week and it's not even noticeable on the bill.
