noob with transmission question
Old Oct 18, 2009 | 05:32 PM
OldBlue68's Avatar
OldBlue68
I have a 1968 ford f100 2wd, it has a c6 transmission not sure what year, and a 79 400m, im having issues tracking down the right tranny mount, where could i look for the correct transmission mount, auto zone and shucks did not work for me . Mabye if someone had the part number or something. Thanks!
Old Oct 18, 2009 | 06:12 PM
BobbyFord's Avatar
BobbyFord
Prolly, the trans mount for a 68, FE, C6 would work.I think think the mounts were specific to trans type and year of crossmember.
Old Oct 18, 2009 | 07:46 PM
jowilker's Avatar
jowilker
Blue, You should be able to use the mount that came in the truck. I still have the one that came in mine with a 3spd. now running a C6. I did have to slide it backwards, and drill new bolt holes.
John
Old Oct 18, 2009 | 07:52 PM
Casey's71's Avatar
Casey's71
I'm thinking that both Instif and John are right. The mount should work as long as it bolts up to that cross-member and transmission. You should be okay ordering one for your truck like would be found on an FE and an auto for that year. If it isn't a perfect fit you can change things up a bit like John suggested.
