Sponsored by: Auxito
Overheating
Old Oct 17, 2009 | 09:50 PM
riverbottom's Avatar
riverbottom
Overheating
97 F-150 4.6l V8 225k. Need Help! Here is my trucks history. On a cold engine overheats after driving less than 10 miles. have excessive pressure in system. T-stat seems to be opening late. I have replaced t-stat, more than once, water pump, radiator, hoses, fan clutch, pressure cap, temp sending unit, cyclinder head temp sensor, and serp belt is within operating range. I also performed a compression check. #7 and #8 were a little weak. I then did a leak down test on all eight cylinders and found no leaks. What could possibly be making my truck overheat?
Old Oct 17, 2009 | 10:23 PM
steve(ill)'s Avatar
steve(ill)
i believe you have a small hole in one of the head gaskets. you have a small amount of cyliner pressure entering your coolant system. i have had this before on a couple vehicles. Go to Auto Zone and get a bottle of "head gasket repair" of similar. It cost about $10. You will need to drain the cooling system and flush with water 2-3 times. no antifreeze left. Then refill with clean water and the gasket repair. Pour the gasket repair into a gallon of water, mix up good, then add it first, then top off with clear water. Start the motor and let it idle for a few minutes. Drive down the road at 30-40 MPH to warm it up a little and let the thermostat open. You dont want a lot of RMP, keep it in the 1500 rpm range, no revving. Run around for 20 minutes and see if you still have the overheating problem. If you wont freeze, let it set a few hours or overnight and run another 30 minutes. Then drain and flush. Leave the radiator open for 24 hours to get thesealer good and hard. Refill with antifreeze.
Old Oct 17, 2009 | 10:25 PM
steve(ill)'s Avatar
steve(ill)
read this
Bar's Leaks Head Gasket Repair
Old Dec 15, 2009 | 06:30 AM
CHRI7S's Avatar
CHRI7S
So did you repair you gasket with this or at a shop? Or did you find another solutioin to your problem.
thomasiovino
Nov 12, 2014 04:21 PM
xayblu
Jul 14, 2010 02:36 PM
fordpride
15
May 12, 2010 09:42 AM
riverbottom
1997 - 2003 F150
Aug 20, 2009 09:25 PM
Faithful Old Road Dog
Jan 10, 2004 12:21 AM
