tranny cooler recommendations ?
i bought some grommets for the holes now and removed the hose pieces.
I guess I missed this yestersday. I think Julie said to get your wife to bend you up some tranny lines. Try that and report back if you can.
Nathan
Not sure if I misinterpretted your post, but I would always run a transmission cooler of some sort on any automatic. Most transmissions will outlast a vehicle if you never overheat them. (Says the guy that dumps my Mustang clutch at 5,000rpms with slicks) Guess this is a good stopping point for my transmission preservation sermon.
I started with a B&M 28,000 gvw rated unit, keeping the factory coolr in line with it.
Worked well and I pulled the trans out at 78k working excellent.
I went with newer, harder hitting transmission, along with a new motor.
I went with a Tru-Cool 45000gvw in line, but did not get the unit that included the cold weather thermostat.
I added that soon afterwards, as the fluid was too cold!
I recommend the Tru-cool unit now, with the temp control if you're up north.
TRU-COOL MAX LPD47391
They are all over EBay......
The brackets are simple sheet metal made in my bench vise with the help of some HF sheet metal forming jaws. The radiators, fans and relays were out of the Summit catalog.
The pictures are of my oil cooler, which is mounted between running board and frame rail under the cab (very hidden) behind the left front wheel. The tranny cooler is identical except the brackets are opposite hand and it is behind the battery box. Both sit at 30 degrees to catch ram air with the help of a flat sheet metal coop. (The running board is removed in the photos).
More info (including part numbers): Ford Truck Enthusiasts User Gallery
Yes the coolers will transfer heat by radiation without air blowing across them, but like your old radiator analogy it will happen very slowly, meanwhile the fluid will pass thru relatively quickly, receiving very little cooling. That's exactly why most homes have turned away from steam radiators (..."used to have"...) for forced air furnaces blowing thru a heat exchanger, much quicker and more efficient. You don't want to wait hours to cool your tranny do you?
At first glance your argument about the radiator being at 200* sounds valid, but in fact the tranny fluid and clutch/band friction materials are designed to work most efficiently at those temps. Running the tranny too cold will damage it as fast as running it too hot. Ever go to a drag race and walk thru the pits? You will see cars using auto transmissions with the rear axle up on jackstands with the rear wheels spinning while they warm up the engine. This is done to also warm up the tranny fluid (as well as the rear axle). Every drive a car with a worn auto tranny that would slip when cold, but then work OK after warming up?
It's not "nuts" to use the radiator, it's deliberately done to keep the tranny in it's operating temp range by heating it up quickly (water to fluid heat transfer is MUCH more efficient as any swimmer knows) and maintaining it there, just as it does with the engine. Think of it as tranny temperature moderation rather than cooling will put you in the right mindset to understand.
Based upon everyone's input, I'm going to get something like a Derale # 13224 from someone like Jegs and run it cross ways just under the front gravel sheild. The particular model should be almost invisible.
Thanks for everyone's input, even fatfender's.
My credo: don't fix a problem until you are sure it IS a problem, the wrong "fix" can create a problem where one didn't exist before.
It's almost November and I live in Canada. I willl now retire to my favorite chair for hockey season. See you next spring truck. Stop me when I tell a lie Robert.
I don't want to beat a dead horse here but which is more efficient, fluid flowing through a small coil submerged in 200 degree water or fluid flowing through a large finned heat sink surrounded by 75 degree (give or take) air? I don't agree with the speed argument that you have raised. A transmission is designed to operate at an optimal temperature of 175 degrees...I guess if you live in a colder climate then you do need to "heat" the fluid by running it through a hot radiator but here in So Cal cold weather is not a consideration. A worn tranny works better when it's warm because the worn clutches, steels, and pump fins expand when they are warm. You have a lot of holes in your arguments so let's just agree to disagree.
(not a tough love statement, but definately no slack)
