tdc number 1
Old Oct 17, 2009 | 07:36 AM
right hook's Avatar
right hook
tdc number 1
how do i determine when the number one cylinder is tdc on compression stroke
Old Oct 17, 2009 | 12:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
right hook,
Welcome to FTE and the IDI diesel forum.
The easiest way is to remove the #1 glow plug, when you feel air escaping as the piston is on the compression stroke just stop at the TDC timing mark on the harmonic balancer.
You should remove the fuel shut off solenoid wire before you crank the engine over by hand to remove the possibility of the engine starting.
Old Oct 17, 2009 | 08:42 PM
PLC7.3's Avatar
PLC7.3
The timing mark is found on a little plate that is on the front of the engine on the passenger side. The plate is mounted so it is very close to the main pulley on the lower front of the engine which is mounted on the vibration damper. On the side of the vibration damper, is a line, which when lined up with the line marked (O) on the plate, tells you that the #1 piston is at TDC(top dead center) You can see the line on the damper, and it points to the line on the plate with the (barely visible)O mark on it.You'll have to find a way to turn your engine over by hand (Crank/harmonic balancer bolt). Make sure you remove the power wire to the injection pump(so the engine won't start)and then rotate the engine until you can line up the marks.
The engine rotates in a clockwise direction as seen from the front of the truck, and for every 1/4 turn of the engine(crank) each next piston will arrive at TDC. So, When the line on the vibration damper is at the 2 oclock position, cylinders 2 and 5 will be at TDC. When the mark is at the 5 oclock position, cylinders 7 and 6 will be at TDC, 8 oclock has cylinders 3 and 8 at TDC, and back to 11oclock, 1 and 4 will be at TDC.
Cylinder numbers are assigned 1,3,5,7 on the right (passenger USA) bank from front of truck to back, and 2,4,6,8 on the driver's side (USA), front to back. Firing order is 1,2,7,3,4,5,6,8.
OK all the above is true...... to ensure the #1 piston is at TDC compression remove the inspection cover on the oil filler/gear cover. You will see a dowel pin from the IP if it is at 4 oclock that is TDC compression stroke, if it is at 11 oclock that is TDC exhaust stroke.......
